Old 08-07-2019, 08:16 PM   #1
Dobe2049
Dobe2049's Avatar
Drives: 2015 Subaru BRZ
D78 connector needed
I am on the hunt for a D78 connector for a 2017+ wire harness. This connects to the clock spring and is found on the dash wire harness.
Plugs in here:
Dobe2049 is offline   Reply With Quote
Old 04-26-2020, 12:26 PM   #2
inmotion
Drives: 2016 Toyota 86
part number
90980-12370
inmotion is offline   Reply With Quote
Old 05-04-2020, 12:53 AM   #3
ihatemy86
Drives: really slow
Originally Posted by inmotion View Post
part number
90980-12370
How did you find this? Also, do you know what contacts that connector uses?
ihatemy86 is offline   Reply With Quote
Old 05-04-2020, 10:29 PM   #4
reh8388
Drives: 2016 Scion FR-S Release Series 2.0
This is how I track down connectors and terminal information from the factory wiring diagrams.
https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
reh8388 is offline   Reply With Quote
Old 05-04-2020, 11:26 PM   #5
inmotion
Searched from taobao(chinese amazon) to japanese web
Contact : 82998-24290, 82998-24300
https://minkara.carview.co.jp/smart/...042/parts.aspx
Old 05-10-2020, 02:29 AM   #6
ihatemy86
Drives: really slow
That is awesome, thanks!
Old 01-19-2021, 01:40 AM   #7
repillows
Drives: 2013 Scion Frs
I am also in need of the D78 connector. How do I find out what the pins are used specifically for on that connector on a Toyota 86? I looked on multiple wiring diagrams and on the repair manual and all I can get is the connector number which is D78 and the pins numbered from 1-14. Reason being is that I'm doing a 2017 steering wheel/clockspring conversion so I can get steering wheel controls. My 2013 uses an equivalent D51 12 pin connector vs the D78 14 pin connector on the 2017+ that plugs in from the dash harness to the clockspring. Both connectors do the same thing but the 14 pin uses extra pins for the steering wheel controls.
repillows is offline   Reply With Quote
Old 01-20-2021, 05:47 PM   #8
reh8388
The manual I linked to has instructions starting on page 20 on how to use the manual to find the connector housing and then with the housing number how to find the part number for the pins/sockets that are listed at the end of the manual.
Old 01-22-2021, 01:38 PM   #9
repillows
will that page also help me find out what pins go to what in terms of their use?
I'm trying to convert a d51 12 pin spiral cable connector from a 2013 into a d78 spiral cable connector from a 2017 by depinning my d51 connector and using the d78 connector to plug into the 2017 clock spring.
Old 02-25-2021, 12:48 PM   #10
repillows
Do you know which contact goes to which? which one goes to the radio and which one to the radio?
Old 03-01-2021, 06:15 PM   #11
reh8388
See my previous post. Page 20 will walk you through step by step how to identify the components you are looking for.
Old 03-01-2021, 07:33 PM   #12
repillows
I got it figured out and my steering wheel, airbag and terminals are on the way as i speak.
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 07:13 PM
ECM Pin Connector simpleisbest Software Tuning 19 01-18-2015 03:13 AM
What's this connector ? mashal Electronics | Audio | NAV | Infotainment 5 12-10-2013 02:13 AM
Help, what connector is this? Hayashi Cosmetic Modification (Interior/Exterior/Lighting) 0 02-26-2013 02:39 AM
VSS Connector AlexTheGreek Engine, Exhaust, Transmission 15 02-02-2013 01:12 PM
