Old 08-08-2019, 07:44 PM   #1
casing
Drives: stock
ATOTO A6 amplifier question.. headunit NOOB
I just installed a ATOTO A6 into my FRS, it came with the proper inline pigtail so I just plugged it in and away she went.
The sound quality is flat and I have no bass. I had the radio on and unplugged the factory amp and there was no change in sound quality so i am assuming the amp is not working with the unit right now.
I see in the inline harness a few wires for me to splice and one says "amplifier turn on" do I just need to splice that wire into the factory "amplifier turn on" wire?
I read the "how to use factory amp" post but it makes no sense to me. I thought the provided harness splices everything for you?
casing is offline   Reply With Quote
Old 08-09-2019, 08:45 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Sometimes universal head units work well with OEM systems, but sometimes there is a little tweaking needed. Likley since the twins have the OEM amp, there needs to be a little modification.
From the way you explained it, it sounds like, the "amplifier turn on" wire does need to be connected. Probably similar to the "remote" wire when installing an aftermarket sub/amp system.
BigTuna is offline   Reply With Quote
Old 08-09-2019, 10:27 AM   #3
MX-5RACER
MX-5RACER's Avatar
Drives: 2018 FA24 SWAP BRZ "ANNIE"
When I installed my A6, I needed to swap one wire in the harness from one pin on the plug to another. Let me see if I can find the post I used to map out the change.
DJ
2008 MX-5 PRHT "Violet"
2018 FA24 Swap BRZ "Annie"
MX-5RACER is offline   Reply With Quote
Old 08-09-2019, 04:47 PM   #4
casing
Drives: stock
Using a wiring diagram i found the factory wire labeled "Amplifier turn on" which is a brown wire - Pin 9- in the 10 pin connector of the factory radio harness.
That specfic 10 pin connector that plugs into the A6's inline harness was empty. So I spliced the "amplifier turn on" wire from the A6 Inline harness to the body harness and my amp works now. I have bass and all speakers work! Thanks guys.
Cliff notes: I spliced that "amp turn on" wire from the A6 inline harness to the factory "amp turn on" wire and my amp now works and have bass.
FS: OEM Pioneer Headunit & OEM Amplifier MicheleAbbate Audio/Visual, Electronics, Infotainment, NAV 26 05-14-2020 04:38 PM
Newb Question, Can I use Oem wiring for full amplifier? YamahaR86 Electronics | Audio | NAV | Infotainment 12 04-28-2016 11:52 AM
Noob question about OFT nyfries Software Tuning 4 12-09-2014 01:07 AM
Amplifier battery wire question!?!? mbh1101 Electronics | Audio | NAV | Infotainment 4 03-04-2013 10:07 AM
noob question ft86me Engine, Exhaust, Transmission 13 02-28-2013 05:53 AM
