I can't even see if my pads are low. Worst brake design ever.
I think the pads are low, but I can’t even see the pad thickness
I literally had the wheels off, and I have no clue if the pads are low. There is no where to see the pad. Totally blocked views. How are you supposed to see if your pads are low? |
ProCrastinationConsultant
take 1 bolt out of the caliper and rotate the caliper out of the way.
#3 | |
Drives: Subaru BRZ Limited
It takes longer to remove the wheel than it does to swap the pads. |
i've never had a set of pads that's easy to see without moving the caliper
Drives: 2015 FR-S
Should have dug up even more dead threads in the brake subforum and see where this goes. Try the Issues/Warranty subforum too. Just get silly.
Drives: 2017 BRZ PP , 2005 Saab 97X
math Mostly
isnt it an interval anyways? check the brake pads every 15k or something? I typically swap em out anyways for what I do and then add that to my list of "check at _____ interval) which literally means take em out and look at how they wear. only pads that are easy to see are those held in place by a snap clip or a single bolt on racing calipers. you got a factory car with sliding calipers. *shrugs* |
Weight Weenie
Drives: 15 FR-S
OP, you need to start reading the DYI section. There’s a DYI for just about anything to do with this car and it’s growing. Take advantage of those who took the time to create them and learn how to do the job before you even start.
Thanks
I agree, I don't like sliding calipers. All exonomy cars should have come with monoblock 4 piston calipers stock.
And that little window on top of the caliper that you can see pad thickness through is stupid too, let's my pads cool off too much when i drive in snow with stock primacy tires.
Wow, I can't believe you actually need to remove calipers just to inspect the pad thickness.
Every other car I've owned, the pads are in plain view. Most cars, you can see the pad thickness without even removing the wheel. What a disgrace. |
#10 | |
And the wheel needs to be removed. How did they make a car where you can't see the pads with the car on the ground? Next time you're in a parking lot, look at any other car You can see the pads without touching a single tool. Last edited by GrantedTaken; 09-08-2019 at 12:25 PM. |
#11 |
TRACKBREAD
look at the caliper from above, you can see the pad plain as day.
if you can't see it, it's damn low. |
#12 |
Drives: 2014 BRZ Limited
God, the whining.
#13 |
#14 |
Hey give him a break. He missed at least two other brake pad threads to whine in. Not even sure what he is looking at on other cars since about 99.9% of them are the exact same setup as this.
I am much more perturbed that I have to open my hood and pull out a sick to check my oil. What is this 1922?
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 01:29 PM |
| Wtb coilovers, brake pads, SS brake lines, engine dress up stuff | IBill4You | Want-To-Buy Requests | 2 | 06-13-2015 04:02 PM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 02:45 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
