Old 01-12-2020, 10:43 AM   #1
Dkfrs
Drives: 2016 FRS
Bent front control arm, options?
I’ve got a bent front right control arm and was trying to look for different options. I figured if I am replacing it, might as well upgrade to something with better bushings.
I see a few brands such as buddy club, racer x, and Megan but not finding a lot of information on this topic. Do most keep the OEM?
Any advice would be appreciated. I do track my car 4-6 times a year and also daily drive it.
Dkfrs is offline   Reply With Quote
Old 01-12-2020, 11:13 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Buddy club comes with their own bushings installed. For an OEM+ setup I think theyre perfect
Old 01-12-2020, 11:54 AM   #3
Stomachbuzz
Drives: 2013 FRS
In my completely uneducated, inexperienced opinion on OEM vs aftermarket control arms...
I would think the OEM ones are perfectly fine structurally, but you need aftermarket control arms for adjustability (correcting the alignment geometry) when lowering the car or wanting a certain type of alignment that the stock CAs don't allow.
If your suspension geometry isn't modified, I might recommend getting an OEM control arm and pressing in the bushings of your choosing
Stomachbuzz is offline   Reply With Quote
Old 01-12-2020, 01:35 PM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
100% incorrect. Control arms are not involved when aligning the front of the car.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 01-12-2020, 05:35 PM   #5
strat61caster
strat61caster's Avatar
wut, yes people do buy aftermarket lower control arms for the front for camber and caster adjustments, the fancy ones also adjust roll centers and anti-dive and in conjunction with a camber plate can be used to adjust track width.
https://www.splparts.com/products/fr...-brz-ft86.html
But that's totally unnecessary for 99.9% of people and I'd suggest OP find some OEM replacements, they'll be cheaper and last longer than the aftermarket ones. Rockauto usually has secondary suppliers if you don't want to pay OE prices for a minor hit to quality.
It's not like the Honda world where the OE arms are hard to find and expensive and it's easier to just grab the cheapo ebay parts and replace them every three or four years if they keep the car that long.
ineedyourdiddly
Old 01-12-2020, 05:57 PM   #6
Stomachbuzz
Drives: 2013 FRS
Yeah, confused me as well.
Hard to understand how a person could think that the most prominent member of your suspension geometry has no effect on the suspension geometry...
Old 01-12-2020, 06:01 PM   #7
strat61caster
fwiw camber plates+bolts are all that's necessary for a quality alignment on this car. Some people can even get away with just a few camber bolts if they're not trying to go past -3° camber.
ineedyourdiddly
Old 01-12-2020, 07:55 PM   #8
venturaII
venturaII's Avatar
Go ahead and buy more race parts then. Make sure to post about why you can't figure out why your car is even more f-ed up than before.
Old 01-12-2020, 07:56 PM   #9
venturaII
venturaII's Avatar
Exactly. But there's always someone who thinks they can make a better mousetrap. And a MacPherson strut front end is pretty much on par with a mousetrap as far as sophistication goes...
Old 01-13-2020, 12:32 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
BC Racing
Tein Flex Z
Öhlins
Old 01-13-2020, 01:01 AM   #11
strat61caster
Having been in all three, they're all the first picture.
ineedyourdiddly
Old 01-13-2020, 01:11 AM   #12
Captain Snooze
Drives: Red Herring
You've been in all three mouse traps?
Old 01-13-2020, 01:17 AM   #13
strat61caster
Yes, save your money and get an exterminator the first time.
ineedyourdiddly
Old 01-13-2020, 02:05 PM   #14
venturaII
venturaII's Avatar
Exterminator = Someone who knows what they're doing
Crank Pulley Pin Bent yesterday... Options? Andew727 Forced Induction 0 07-29-2016 12:30 PM
Jackassery, hit curb in FRS bent control arm Doughboy Issues | Warranty | Recalls / TSB 24 10-03-2014 04:08 PM
What control options do you always drive at? (Manual) Alltezza BRZ First-Gen (2012+) — General Topics 95 04-21-2014 01:14 AM
Bent lower control arm Notso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-13-2014 09:52 PM
