Old 01-30-2020, 06:48 PM   #1
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
First Suspension mod help.
Hello all,
I am looking into doing a suspension mod where I have some adjustablity. I have never done this type of mod before where there is an adjusting component. Last year was my first major year tracking racking up close to 500 laps during the spring/summer/fall on all stock suspension. The first adjustable mod I had in mind was either adjustable sway bars or coilovers.(something good quality as well) I went about doing some research on the forums I saw a lot of discussion talking about sway bars and how the factory setup is great and they aren't adding a lot of value from a handling perspective. This really put me off buying sway bars. So I am looking into deciding between coilovers(something nice but 1 way adjustable) or sway bars.. I don't want anything too complicated for my coilovers as it may overwhelm me in the process of dialing in the car. Hoping some of the more experience people could give me some guidance in what mod I just start with.
Driving types this BRZ will need to handle:
* 0-3 times a week on the street
* 15-20 track days a year.
* 3-8 drift days a year.
Note: a valid answer is drive more time on stock before upgrading. Dont be afraid to suggest that.
Thanks!
Elliotw is offline   Reply With Quote
Old 01-30-2020, 07:21 PM   #2
FastWhite
Drives: Subaru BRZ Limited M/T
First question then is “how much do you want to spend ?”
Look for a reputable vendor
Find a friendly face and drive their car
Do one thing at a time
With this platform, stock sway on the rear
Front bar gives you better turn in
Some Tein coilovers are designed to work with stock bars
You’ll get a ton of opinions
CSG is on the west coast
RCE on the east
Both have excellent reputations.
Drift Office is also excellent. In Auburn WA.
FastWhite is offline   Reply With Quote
Old 01-30-2020, 07:28 PM   #3
Code Monkey
Drives: Subaru BRZ
MCS or wait for the Xidas.
Code Monkey is offline   Reply With Quote
Old 01-30-2020, 07:28 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
CSG Spec Flex A's are a solid choice.
I am curious how the suspension from Annex works out. I can see on FB some of the guys in Norcal86 are playing around with them.
Old 01-30-2020, 07:51 PM   #5
Elliotw
Elliotw's Avatar
Any thoughts on Sway bars vs Coilovers. It seems most are just suggesting coilovers to choose from.
Budget:
< 5k coilovers
< 1k sway bars(front & rear & end links) Although it seems rear isn't recommend.
Old 01-30-2020, 08:39 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Budget:
< 5k coilovers
Old 01-30-2020, 09:19 PM   #7
FastWhite
At 5K for coilovers go MCS. 1WNR, front sway only. I like the 22mm Perrin. Get poly bushing for the rear. The SPL front end links. Determine how low you want to go and then decide on regular or shortened version of the endlinks.
Old 01-30-2020, 10:17 PM   #8
strat61caster
strat61caster's Avatar
Don't change anything until you know what you're trying to change. This sounds like throwing parts at the car just because you have some money in your pocket. You haven't described any problems you're trying to fix with suspension mods so it sounds to me like you got a flawless car.
ineedyourdiddly
Old 01-31-2020, 03:25 AM   #9
Elliotw
Elliotw's Avatar
Appreciate the honest feedback.
Old 01-31-2020, 05:08 AM   #10
Buy 2-3 more sets of stock suspension. Swap them on every 200 laps or so, because stock dampers wear out QUICK.
Spend the rest on seat time, brake pads, tires, and maintenance.
Old 01-31-2020, 07:23 AM   #11
M0nk3y
IMO - Diving into MCS suspension isn't worth it until you can afford (and want) 2-Way Remote Canisters. Their valving and internals on the 1-Ways and 2-Way non-remotes are meh.
For front swaybar, I highly encourage you to look into the Karcepts Front Bar. If you want adjustable - that has everything you could ever want.
Until then, focus on track time - getting comfortable with the car and truly understanding what you want out of your suspension package. Nothing is worse than throwing an expensive shock on the car and not really grasping what that shock is doing or how it is benefiting you.
IMO
Kyle H. - #89 STX
Old 01-31-2020, 10:42 AM   #12
strat61caster
Would Bilstein last long enough to warrant the price difference?
ineedyourdiddly
Old 01-31-2020, 11:21 AM   #13
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Thanks!
The question to ask, is "what behavior of the car are you looking to change"?
If there is nothing you've identified that you want to change, there's no point in changing anything.
Just buy tires and track time, rinse/repeat.
Joesurf79 is offline   Reply With Quote
Old 01-31-2020, 11:26 AM   #14
Joesurf79
Joesurf79's Avatar
IMO
So - tell me about the benefits of the remote canister vs the "meh" 2WNR if you would On what tires, sizes, spring rates, aero setup? Because I've had nothing but great luck and lap times with them, and they damping sweep covers a dramatic range of spring rates...
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 08:10 PM
Looking for OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 1 01-06-2018 12:43 AM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 11:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
