Old 02-01-2020, 03:03 AM   #1
Ranran
Drives: 2017 86
KW coilover boxing sloppy?
I ordered a set of club sports from 86speed and the packaging the coilovers came in look strange to say the least. Every other video of unboxing online the boxes are nice and relatively flat compared to the box that got delivered. And there’s no plastic straps, only tape holding it together. Is this normal? Or should I be worried of authenticity?
Links to pictures because I cant upload big images.
https://imgur.com/a/r64Na3G
Ranran is offline   Reply With Quote
Old 02-01-2020, 05:02 AM   #2
Phuviano
Drives: FRS RS 2.0 #757
I don't own any coilovers for the matter, so take my advice with a grain of salt.
I did watch a video of an unboxing of the KW clubsports. It could be a possibility, that someone else bought these, opened the box, but didn't end up using them. Then taped up the box, and hence the reason, no straps on the box.
The delivery guys rarely ever handle packages with care, so boxes that don't look in the best condition aren't a surprise to me, ever.
Did you actually open the box, and check the contents inside?
If you're still unsatisfied or unsure about the product after you open the box, then contact 86speed at that point, and voice your concerns.
Phuviano is offline   Reply With Quote
Old 02-01-2020, 06:04 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well, you did step one right. Taking pictures before you open the box. As so "this is how it was delivered".
Second: Open them up. Inspect the parts. If they looked damaged then talk to the customers service. Then go from there.
Old 02-01-2020, 12:29 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I just got regular V3s, but mine came in a much more "normal-looking" box, IIRC. It was just the "pretty part" of the box in your photos.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 02-01-2020, 05:26 PM   #5
Ranran
Drives: 2017 86
So I did open the box, the coilovers are on top of each other separated by cushion, which isn’t that bad. But the coilover them selves seem damaged or not aligned. The nut on the top hat is somehow lodged under the opening and it’s making the whole top hat slanted. Is this normal?
Pics to opened package and top hat :
https://m.imgur.com/a/DGH73ng
Old 02-01-2020, 05:27 PM   #6
Ranran
Drives: 2017 86
Did your coilover top hats look like this?
The bolt is somehow lodged under the tophat
Old 02-01-2020, 06:08 PM   #7
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Did you buy "reconditioned" parts? Cause it looks to me like they just put new top hats on them.
Can't really see the bottom part where it connects to the struts but it looks scratched. Or unless it's super shiny?
Old 02-01-2020, 10:59 PM   #8
StraightOuttaCanadaEh
Wes
My box looked pretty beat up as well. The coilovers are HEAVY and the box really has it rough.
Instagram: @gt86ws
Old 02-02-2020, 12:17 AM   #9
Ranran
Drives: 2017 86
No I didn’t, they were advertised as new. :/
Old 02-02-2020, 10:19 PM   #10
Stang70Fastback
A.K.A. Starlord
The V3s don't come with top hats, but if they had, I'd have been pissed if they looked like yours do. I'd definitely be having words with the seller over those "new" coilovers.
Old 02-03-2020, 12:44 PM   #11
Corley
Drives: 2014 Stock frs
I received my KW's last week my top hats do not look like that. Looks like shipping damage. Mine were double boxed with plastic straps holding it all together. Do have any shipping paperwork?
Corley is offline   Reply With Quote
Old 02-03-2020, 12:51 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have those same marks on my camber plates, from me using a screw driver to slide them over when adjusting them.
Look like they have been mounted to me. Other pictures are not detailed enough to tell.
Old 02-03-2020, 04:27 PM   #13
Ranran
Drives: 2017 86
No I only have the invoice for my order. Should I ask for shipping paper work?
Old 02-03-2020, 04:36 PM   #14
Racecomp Engineering
If the torx locator bolts on the camber plate are stripped that's not acceptable. It's hard to tell for sure but the one looks pretty chewed up.
- Andrew
Lug nuts have a sloppy fit in 19mm socket. pcguru2000 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-31-2018 02:13 PM
Shifter is obnoxiously sloppy Takumidesh Engine, Exhaust, Transmission 14 04-25-2017 03:58 PM
Sloppy throttle pedal allowe Engine, Exhaust, Transmission 23 11-02-2016 03:11 PM
Boxing Day Deals (OFT, etc.) Chad86 Scion FR-S / Toyota 86 GT86 General Forum 4 12-23-2014 02:21 AM
boxing DIG1992 Off-Topic Lounge [WARNING: NO POLITICS] 6 05-09-2012 02:00 AM
