Old 04-03-2020, 08:57 PM   #1
FRS Megan
FRS Megan's Avatar
Drives: 2015 Scion FR-S
FRS Fitment help !!
So my set up is looking like:
Konig Oversteer 18x8 +45mm offset
Eibach lowering springs (1 in )
Now will 245/40 square be okay all around ?
Or will 235/40 be the better option?
I do not want any poke in the front, I want it to be flush. I can add spacers to the back if needed.
Thanks
FRS Megan is offline   Reply With Quote
Old 04-03-2020, 10:17 PM   #2
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
I would do a 225/40/18 on that wheel spec. If you had to do a 245, it would be a 245/35/18 as it is very close to OEM diameter, cheaper, and there are more options for that size. You will need spacers for it to be flush.
Will BRZ is offline   Reply With Quote
How's the fitment of 1320's dual res fp fitment on AT aznchris Engine, Exhaust, Transmission 0 04-16-2019 07:02 AM
TRD Kit fitment Ds3ire Cosmetic Modification (Interior/Exterior/Lighting) 20 03-16-2016 04:11 PM
Help on Fitment! lxsedan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-07-2015 11:01 AM
XXR fitment help raven1231 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-01-2015 02:05 PM
