Old 04-18-2020, 10:19 PM   #1
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
Rear brake assembly smoking, making clacking noises. See video
After I drove home today and parked I discovered loud clacking/clicking noises coming from my rear. I don't know is this coming from the brake pad or my rotor?
Also there was smoke that smelled like burnt rubber coming out from there as well. And my center hub logo fell out somewhere too.
My rear brake pads and rotors and tires are two years old and due for replacement. Not sure if they are 100% done yet, but does anyone what exactly happened here and is this the pad or rotor or both or what?
here is a video of it
morswestford is offline   Reply With Quote
Old 04-18-2020, 11:52 PM   #2
Code Monkey
Drives: Subaru BRZ
Seized parking brake or calipers, too much heat build up, and the metal parts make clicking noises as they cool down?
Code Monkey is offline   Reply With Quote
Old 04-18-2020, 11:56 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
time to take it apart!
Old 04-19-2020, 12:17 AM   #4
Lantanafrs2
Drives: 2013 frs red
That sounds scary. Pull it apart
Old 04-19-2020, 12:29 AM   #5
morswestford
yeah figured it could also be a caliper. bah. just my luck. the car still overall drives just fine though. but i guess ill gingerly drive it over next week for service. probably ill need a whole new caliper, pad, maybe rotor. damn. this happened to me two years ago as well. but that time i was braking too hard and then the caliper did something and broke along with the rotor.
the calipers i have are the stock subaru calipers.
the brake pads i have are stop tech brake pads.
the rotors i have on the rear are Hawk slotted and drilled rotors. (these are horrible, im never buying these again). My front rotors are Stop tech drilled rotors as well as stop tech pads.
Should i just stick with the stop tech drilled rotors and stop tech pads then if i need to replace that as well?
Old 04-19-2020, 12:33 AM   #6
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Yup, had that issue on my S2000 years ago, most likely a seized caliper. Did you keep up with brake fluid changes?
Old 04-19-2020, 12:51 AM   #7
morswestford
yes all my fluids are good which is weird. i regularly maintain the vehicle. so i dunno why this happened twice in two years.
Old 04-19-2020, 01:25 AM   #8
B-R-Z
B-R-Z's Avatar
I had this issue reoccur on me as well, in my S2000.
To be honest, at the time I was broke and in college and wasn't keeping up with the brake fluiid changes so when the first one happened, I was not surprised. But within a year or so after replacing the caliper with a refurb, and flushing fluid, the same thing happened again where it seized and caused wheel heat. Are you buying new calipers or refurbs? I am wondering if the refurb process is flawed because I was surprised for it to happen again after putting in fresh fluid.
Old 04-19-2020, 01:55 AM   #9
Is the parking brake handle down?
Old 04-19-2020, 03:11 AM   #10
morswestford
interesting story. my calipers are brand new, stock from subaru.
Old 04-19-2020, 03:12 AM   #11
morswestford
well right now since the car is parked, its up. why
Old 04-19-2020, 03:20 AM   #12
B-R-Z
B-R-Z's Avatar
Ok, so you're on original calipers and you have kept up with brake fluid changes? Maybe just a faulty caliper.
Old 04-19-2020, 10:13 AM   #13
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
I have calipers, rotors...anything you may need.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 04-19-2020, 11:10 AM   #14
Does pulling it up and releasing it feel right?
Was it completely released when you were driving?
The E brake is a drum so you can't see if it is stuck on.
Is the rotor discoloured at all?
brake pad, clacking noise, clicking noise, rotor, smoking
Noises coming from the rear or trunk area? It might be this... Lightened Issues | Warranty | Recalls / TSB 9 03-13-2020 09:54 AM
Transmission is making noises, any1 can help identify the problem? PurpleSpaceShip Engine, Exhaust, Transmission 31 06-12-2018 08:34 PM
Normal Engine Noises? (Audio/Video Clip Attached) MyEvilMonkeys Engine, Exhaust, Transmission 7 12-24-2013 05:15 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 11:28 PM
