| Member's Car Journals Car journals by our members. |
Dysentery Enthusiast
Drives: 2017 toyota 86
17' Eight Six - HDPE - AC -Touge - Light Duty Track - Daily Driveable Year Round
Here's the Mod List So far.
Engine and Performance HKS Supercharger ATI Superdamper 10% under driven and 95mm Pulley on Supercharger 95mm Pulley 3.74" + ATI Circumference 11.75 * 9.888 Gear Ratio = 100,126 RPM@7500 (This is 5000 RPM more than Stock but 5000 Less than High Boost pulley from HKS) K&N Drop In Air Filter - Greddy Air Scoop - Crawford Billet Power Blocks Delicious Flex Fuel Kit and Tune - Injectors and Pump - Skunk2 Stepped Equal Length Header Mid and Over Pipe (can't remember brand) Ark exhaust Modified to be single Exit Suspension Brakes and Handling St Suspensions X Coilovers - Wilwood Front brake Rotor Replacement - Sport Edition P4 Rims 16x7 +35 - 225/50R16 General AS-05 P2M Lower Front Control Arms Tie Rods End Links and Rear Tie Rods - Whiteline Adjustable Rear Control Arms - Whiteline Sway Bars DC Tower Brace - Full Tom's chassis Bracing including sway bar braces Aero Outside Sard Style Spoiler - DIY Plywood Splitter - Cut Rear Bumper. Diftech Adapters, Wilwood Calipers on Stock Rotors braided steel lines. https://www.ft86club.com/forums/showthread.php?t=139903 - modified to fit nicely Last edited by RuyGuy2; 06-06-2022 at 01:35 AM. |
Drives: C5, GT-86, '24 Colorado TrailBoss
Interested in the ABS delete. Mainly how you will bypass the Computer. And have you considered the Chasebays brake booster delete
I'm going to leave the computer hooked up and let the manifold sit above the abs unit put some internal plugs in to keep it clean. The idea is to make this easily reversible. I do intend on getting a chase bays booster delete Unit.
Loves the Smell of Track
Drives: '13 86
What are your alignment specs?
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD http://www.ft86club.com/forums/showthread.php?t=7934 |
Alignment is something I really should learn more about, I feel like this car would benefit from more castor?
I didn't want to be to aggressive, I don't want to wear out my tires too fast. Front 2* camber 5* caster 0* toe Rear 1.7* camber 0* toe |
Drives: 2016 FRS RS2, (sold) 2019 Raiu BRZ
Cool build. How long did it take to install the AutoBlip? Whats your review on it? Thanks
| Transmission/Differential oil change interval daily + light track use | GCFSA | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 03-11-2020 06:44 PM |
| Functional, Double Duty Daily/HPDE with a BUDGET | dattran86 | Member's Car Journals | 175 | 01-19-2019 09:32 AM |
| WTB: FRS/BRZ for HDPE/track days | GrandSport | Want-To-Buy Requests | 2 | 10-30-2018 08:53 PM |
| BRZ Functional DD-AutoX-Light Track Duty Budget Build | dattran86 | Member's Car Journals | 11 | 01-21-2018 01:35 PM |
| At what point is your car no longer daily driveable? | unsurety | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 04-04-2014 01:55 AM |
