Old 05-07-2020, 10:41 AM   #1
theneptune86
Drives: Neptune Blue 2019 Toyota 86
Cool Neptune Blue with Ceramic Pro installed
Over the moon with how she turned out--the blue is even more amazing after the corrections/ceramic coating!
Also beginning to work through photos from the day of pickup (including this sunrise) so I can flood IG:
theneptune86 on instagram
2019 Neptune Blue Toyota 86 • Gruppe-S UEL Catless Headers • OFT Stage 2 Plus (91)
theneptune86 is offline   Reply With Quote
Old 05-07-2020, 11:42 AM   #2
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
Beautiful! Excellent cinematography as well. Needs a soundtrack.
Bobharp is offline   Reply With Quote
Old 05-07-2020, 12:35 PM   #3
theneptune86
Thank you! Will definitely be making an edited down version with other clips and some of the photos once I'm through editing them.
Old 05-07-2020, 05:30 PM   #4
radroach
Drives: car
I hear that ceramic coats look even better as they have time to cure.
And I'd say the opposite, no soundtrack needed! Silence is golden.
Old 05-13-2020, 11:49 AM   #5
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
No badge up front? Do you have to wait to reinstall one?
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 05-14-2020, 09:20 AM   #6
theneptune86
Well, I ordered the flat black "86" stylized badges back in October. When time came this spring and I booked my spot with the detailer, I finally debadged and test fit the badges, and they were way off in fitment...meant for 13-17 FRS style bumpers. So in the car went to the detailer without badges..2 days later my replacement-replacements arrived:
https://www.ft86club.com/forums/show...1036&page=1562
(not sure how to reference a specific post, sorry for noob--scroll to around the middle of this page)
Old 05-14-2020, 01:33 PM   #7
ActionMaxon
When you took off the badges, did you use floss? I was thinking of removing the "frs" from the trunk for symmetrical reasons but I don't wanna damage the paint
2016 Oceanic
Old 05-15-2020, 03:02 AM   #8
guitarman
Drives: 2016 Scion FR-S
I know what you mean. I ended up adding a sticker to the other side to kind of balance the FRS badge. Works OK.
guitarman is offline   Reply With Quote
Old 05-15-2020, 08:29 AM   #9
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
heat gun, 3m adhesive remover, hot day, tons of patience. People have used hair dryers successfully instead of a heat gun.
Old 05-15-2020, 08:36 AM   #10
theneptune86
The floss did indeed leave some marks, but probably wax/whatever is on the floss transferring onto the clear more than the clear being damaged. Any marks from the floss were pretty easily compounded out.
The process is a job and a half though, most of my time spent on the front badge. Not easy, not for the faint of heart. Toyota has those badges on with some sort of super 3M, and the locating/fastening pins on the front badge are in there super good...broke those, the emblem was in-tact, but I'm pretty sure you don't have locating pins on the FRS so some heat and the floss should fly right through. Be ready with some compound/polish to clean up inevitable smudges/scratches induced, but you'll be good!
Old 05-15-2020, 08:36 AM   #11
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea the key is getting it nice and hot. I set up a hair dryer at max settings for 10 mins, then dental floss in a sawing motion to get it started. Adhesive remover can help, but only after you remove all the double side tape foam chunks. After it’s all off hit it with a mild hand polish (like ScratchX) and get some wax on it.
Old 05-15-2020, 02:08 PM   #12
ActionMaxon
Wow thanks for all the tips. I don't know if I would have thought to apply heat first in this case, but it makes a lot of sense. Might have to give this a go soon. I wish someone made a bronze badge set up. That'd look killer on the Oceanic paint
2016 Oceanic
Cruise to Neptune's Net Sunday June 25th, 2017 iAm_Neri Southern California 2 06-25-2017 05:25 AM
NEW Canyon Cruise - Neptune's Net - Socal Valley 86 chjno86 Southern California 64 04-07-2014 12:02 AM
Invasion of Neptune's Net (part 2) 20valvewynn83 Southern California 25 12-14-2013 05:16 AM
EAT MEET and DRIVE :) NEPTUNE'S NET MEET SUNDAYS ric342 Southern California 54 10-14-2013 02:54 AM
car show today, neptune NJ FRS-Jonathan NY / NJ / CT / PA 0 07-14-2013 11:29 AM
