Old 05-21-2020, 02:42 PM   #1
haloterence
haloterence's Avatar
Drives: 2013 whiteout fr-s
Rear axles loose?
I just had both my rear axles replaced. There was some clunking sounds during hard acceleration. So I went under the car and notice both axles had some moment. Is this normal?
haloterence is offline   Reply With Quote
Old 05-21-2020, 03:16 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That play is fine. Most likely the clunk is the axle nuts, common issue. Did the shop replace the axle nuts when they replaced the axles?
Old 05-21-2020, 04:04 PM   #3
haloterence
Yeah, both had new nuts replaced. Thanks for the reply. I'll check if the nuts were torque to spec.
Old 05-21-2020, 04:18 PM   #4
humfrz
You say there was some clunking sounds. Are those sounds still there after the axles were replaced?
Is that movement normal? I don't know for sure, but unless they made noise, I wouldn't worry about it. And, no, I'm not going out and crawl under my car to check mine, because I don't want to get my bathrobe all dirty.
BRZ Rear Axles j_ros94 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-16-2019 10:01 AM
Wtb rear axles Phothiraj Want-To-Buy Requests 0 02-24-2017 10:58 AM
WTB: OEM Rear Axles RedFR-s Canada Classifieds 0 10-23-2016 09:28 PM
rear end and axles Duce69 Engine, Exhaust, Transmission 2 07-20-2016 10:21 AM
WTB: DSS 600hp rear axles SterlingBrz Want-To-Buy Requests 1 03-17-2015 08:49 PM
