Drives: 2015 Black Scion Fr-s
Scratch when accelerating and shifting
I keep having this scratching sound when I press the pedal all the way down suddenly or when I shift at a high rpm I read online if could be the heat shields but I have replaced the headers, over pipe, and front pipe and it’s still doing this any ideas ?
I can't sort out that sound you are referring to.
What is the last thing you did to your car before it started making that sound? I'd suggest you start there. |
It’s been doing it for a while since even before I did any modifications but I did my headers last and it hard to catch on video but you can hear it at 4seconds on the video
Drives: car
Lets get this out of the way: That shifter, whew..
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
have you checked if the new over pipe is rubbing?
NARFALICIOUS
Noob Poster 1988 | 2016 |
Rust bucket enthusiast
Can't hear anything. Based on the timing I'm curious if it's the syncro grinding (would not happen if it's just when you press the clutch down suddenly though). For what it's worth, that is not high RPM that you're shifting at. Sounds like about 2700 rpm.
Have you done anything with your transmission/clutch/clutch pedal? Maybe your pedal needs to be adjusted if you've modified this system at all |
friendly
Drives: 17' 86
yeah probably the shifter
Seek comfort in discomfort.
The Dictater
Drives: '13 Red Scion FRS
Mine has done that since new. It is likely the sound of air quickly entering the intake plenum through an opening throttle. Purse your lips and quickly breath in, makes about the same sound. Don't hyperventilate though...
#9 | |
#10 | |
There are a lot of places to upgrade and spend money on, you'll need to pick your battles |
#11 |
#12 |
The Dictater
#13 |
Ooooooo ....... I think she could handle it -
#14 |
UPDATE : I've notice it only doesn't do it when the car is cold and it only does it when going into second and third gear anything above that it won't. It does it when I switch gears above 2k rpm.
| VVT goes off for 1 second accelerating in 6th | tomm.brz | Software Tuning | 16 | 10-31-2018 12:44 PM |
| Not accelerating | Fresh31 | Issues | Warranty | Recalls / TSB | 15 | 03-17-2018 06:05 PM |
| Pop noise when accelerating sometimes | Jfheisenberg | Engine, Exhaust, Transmission | 5 | 10-09-2017 08:39 PM |
| Please help.. Car not accelerating | Joseph | Issues | Warranty | Recalls / TSB | 9 | 09-08-2015 12:55 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 06:09 PM |
