| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 Whiteout FR-S
Solution Found: Rear Deck Rattle
tl;dr The wireless transmitter is loose!
There was a horrible rattle that sounded like a screw or something loose rolling around coming from the back of the car. Dealership didn't put any effort into finding it so I had to find it myself. I figured out that if hit my palm against the bottom of the deck on the driver's side I could replicate the sound I was hearing when driving. After removing the rear deck, I discovered that the wireless transmitter was too loose. Solution: 1. Take the rear deck out. There are multiple ways to do this--I pulled the plastic pins out that you see when you put the rear seats down and then was able to pull up on the deck after locating the 4 plastic grommets. This is much easier than totally disassembling the rear pillars, etc. Do this at your own risk--you can easily bend or crease the deck if you get in a hurry. 2. Locate the wireless transmitter and find an appropriate sized socket. 3. You can tighten the bolt and see if that fixes your rattle. However, I wanted to make sure I never had to get back there again so I cut a small rubber placemat the size of the transmitter (and a hole for the bolt) and placed it under the transmitter. 4. Tighten the bolt and be rattle free. I've not heard the noise for over two weeks. 5. When you reinstall the rear deck, make sure you push down on it so that there is sufficient clearance between the brake light and the window or else you will hear rattle! ![]() ![]()
Drives: Mint-Tiffany blue FRS
good job
Waited 5 years for this
Drives: '18 MX-5 Club
Wireless transmitter for what?
It is bolted on but was not snug. Even when I tightened it all the way, I was not sure if that small padding on the bottom of the transmitter provided enough pressure to keep the transmitter from rattling.
Drives: Hot Lava A/T
Drives: 2011 Civic Si
I think this is my issue. Does this sound like a metallic buzzing when it occurs?
#10 |
You are the man, this is what I am getting.
Can't wait to fix this tomorrow
#11 |
Drives: Firestorm FR-S
I don't have an issue (yet) but if I do I will look there first. Thanks for posting this and hopefully this helps a lot of people that are being driven mad by random sounds in their cars.
#12 |
Drives: Whiteout FR-S
I'll check this when i add some sound deadener this weekend, going to do a little work in the trunk and rear deck areas.
edit: don't have a noise in mine but going to get pro active |
#13 |
Drives: 2013 Argento Silver Automatic FR-S
Well done! :happy0180:
#14 |
Drives: FR-S 2013
thumbs up XD
| How-To: Remove Rear Deck & Third Brake Light | Moshpit37 | DIY (Do-It-Yourself) Guides | 63 | 08-01-2020 10:48 PM |
| Rear Deck "popping/clicking/tapping/ticking" noise. | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 637 | 04-28-2020 05:55 AM |
| Solution Found: Rear Deck Rattle | jdubz | Issues | Warranty | Recalls / TSB | 29 | 10-13-2019 03:48 PM |
| My Front Plate Solution | Flat Black VW | BRZ First-Gen (2012+) — General Topics | 55 | 11-06-2012 10:07 AM |
| do you think the rear deck rattle... | pr086 | Issues | Warranty | Recalls / TSB | 7 | 08-03-2012 05:35 PM |
