| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 M/T Limited WRBP BRZ
You guys with Limiteds, hows your climate control working?
I was just wondering if anyone else is experiencing the same thing I am.
My 2007 STI had climate control which when I set it to a specific temperature it not only adjusted fan speed but the temperature of the air that came out of the vents adjusted too. Setting it to 74 kept me pretty comfortable and I didn't have to touch it. With the BRZ the climate control only seems to control fan speed. When I get in my car and its scorching outside I turn it down to low 70's and as it cools off the fan speed adjust accordingly but the air coming out is still freezing. forcing me to turn it up to 80-82 so its barely blowing. Even then its still lightly blowing ice cold air constantly. WTF! It's gotta be broken or was this part sourced from Toyota and this is how their climate control works. Is anyone else experiencing this? and just for so you know. I do have it on "FULL AUTO" and have high grade 3M tint. Also inb4 "first world problems" |
Drives: CBS BRZ limited MT
I don't really like having it on full auto. I prefer to adjust the fan speed and temperature separately.
That being said, when I adjust the temperature, I have noticed that the air coming out the vents does indeed change temprature slightly. I will experiment with the auto feature and see if that's different. I wouldn't think so, though. |
I just manually set it to a temp and then a fan speed. I never really liked how the fan speed will jump up to full speed, even when it's not needed.
Also, curious, but does anyone notice that if you turn the controls on, the AC comes on as well? I'd be nice if it didn't do that, since I have to turn it off right after if I'm not going to use it. I have a feeling it'll put more wear on it in the future.
Drives: 2017 WRB PP
I have mine set at 69 and I don't think the car has ever really gone off of full blast. It feels cool but it has never actually been cold in the car at all. I also have darkest legal Llumar ceramic tint and it lowered the temperature in the car from 160 to around 140 when I get in after work.
So I wouldn't know... Sounds like you could just turn the knob down in speed if it gets cold. I had to do the same thing in my M3 because that bitch would make it snow |
Black Blood of the Earth
Drives: The Porkchop Express
Mine works as it should. The temp of the air indeed does change depending on the setting. I only wish there was an option for cooler air without using the AC. But overall, I am content with it.
It's all in the reflexes.
#6 | |
AIM4APX
Drives: 2013 WRB BRZ Limited
Same here.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#7 | |
Drives: '13 BRZ Limited '10 370ZR
Drives: Non-BRZ
I think I might have a problem with mine then. No matter what temp I set it to, if the AC is off, the vents blow warm air.
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
With my other Subaru, the non-AC vent would blow at coldest, about 5-10 degrees warmer than outside air. (I suspect due to plumbing the air past the hot engine.). So when it's 68 outside, the vent will blow at 75 or so.
#10 |
Drives: '13 Subaru BRZ Limited WRB
The engine in this car rejects a huge amount of heat into the passenger cabin; between Alcantara seats on the Ltd and turning off the A/C, I recall that some reviewers very easily started sweating when it was only 60 or 70 degrees out. Warm air coming out the vents, as @ashtray said, could just be ambient outside air warmed by proximity to the engine.
#11 |
Drives: TR2,CooperS,BRZ
Do people notice the engine temperature running cool even when it's hot outside? My other subarus always ran with the temperature gauge showing at the mid position.
#12 |
I think you've misunderstood. The AC needs to be on in order to properly use the climate control. I even mentioned that without the AC on the air is never cool. Your climate control works just like mine does.
#13 |
I don't quite understand how the air could get cooler without the A/C on. What I meant was that with the A/C on, the temp of the air seems to vary with the temp setting
#14 |
After proper warmup, I am a hairline below dead center on the temp gauge. Even in this heat we are having.
| BRZ -> FRS Climate Controls Retrofit? | kndonlee | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 05-26-2015 03:34 AM |
| Ground Control is working on some stuff for us :) | D1cker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-24-2012 07:21 PM |
| Traffic Nav Not working on my BRZ | Indestruct | Electronics | Audio | NAV | Infotainment | 9 | 06-19-2012 10:38 PM |
| Auto climate control | Daemione | Electronics | Audio | NAV | Infotainment | 37 | 06-05-2012 10:19 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
