Old 08-06-2020, 03:48 PM   #1
mauly
mauly's Avatar
Drives: 2016 BRZ Limited
Timing CELs after 2017 engine swap into 2016
I recently installed a 2017 A/T engine (black manifold) into my 2016 a/t brz. I transferred every single sensor and the complete wiring harness from my 2016 engine, to my new 2017 engine. The car starts and runs okay for a minute but then gives me P0011 and P0021 CEL (timing over advanced) Do i need a different tune for the 2017 engine to run correctly?
mauly is offline   Reply With Quote
Old 08-06-2020, 03:55 PM   #2
padillaricardo48
padillaricardo48's Avatar
Did you check the VVT??
Sent from my SM-N975U1 using Tapatalk
padillaricardo48 is offline   Reply With Quote
Old 08-06-2020, 04:52 PM   #3
mauly
mauly's Avatar
I changed all the Vvt sensors from my 2016, but it makes no difference, i also put the 2017 ones back but still throwing those codes, im just wondering if ill be able to have it tuned out or need a new ecu
Old 08-06-2020, 05:23 PM   #4
padillaricardo48
Tbh you need a new ecu and erase the codes but first try to erase the codes then if it comes back than u need a new ecu
Old 08-06-2020, 07:54 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
From the document of changes between 2016 and 2017. Long story short, all the toothed wheels are wrong for a 2016 ecm to understand what they're doing.
Blown 2016 FA20 swap 2017 FA20 HRLQN Engine Swaps 11 10-15-2019 08:17 AM
2017 BRZ Cracks on Timing Cover is this normal? arren123 Issues | Warranty | Recalls / TSB 13 01-30-2018 10:49 AM
Engine timing? MJferg Engine, Exhaust, Transmission 3 05-13-2017 08:38 AM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 02:56 AM
Engine Mods and CELs Captain Snooze Engine, Exhaust, Transmission 2 04-08-2013 11:13 PM
