Old 09-12-2020, 02:17 AM   #1
j_ros94
Drives: 2017 Subaru BRZ
Hissing noise
Maybe i just didnt notice it before but i started hearing hissing noise when I accelerate at least at 4th gear up. I'm not sure if that's turbo spool but i never noticed it before. It goes away when i take my foot off the gas and i hear the bov go off.
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 09-12-2020, 02:18 AM   #2
j_ros94
Was just hoping for someone to confirm or deny if the hissing noise is turbo spool
Old 09-12-2020, 11:51 AM   #3
p1l0t
p1l0t's Avatar
If you are at max boost it is probably relieving excess pressure. I have a twin scroll in my JDM STi swap (not a BRZ) and it makes all kinds of noises at many different throttle pressures/rpms. The only time it's not dumping pressure is on the inital acceleration but as soon as the first stage spools up it hisses a little and then when the second stage kicks in it makes a fluttering sound and the when I back out of the gas to shift it dumps even louder. So yeah it's probably normal. If you have a boost gauge you probably notice the noise starts around your max boost point (although there are many varibles).
Old 09-12-2020, 04:45 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
Is your car SC'd?
Old 09-12-2020, 05:09 PM   #5
j_ros94
Is your car SC'd?
No Turbocharged
Old 10-07-2020, 08:31 PM   #6
colin88
Drives: 2013 Toyota 86
Originally Posted by j_ros94 View Post
No Turbocharged
Can you describe the "hiss"
Does it vary in pitch or constant
Could be a minor boost leak
Could be surge
Sent from my SM-N975F using Tapatalk
colin88 is offline   Reply With Quote
Old 10-07-2020, 09:01 PM   #7
j_ros94
Could be surge
Constant pitch only when flooring the car above 4k rpm
Old 10-07-2020, 09:02 PM   #8
colin88
If you could take a video it would help, still could be surge or boost leak *minor
Hissing noise after turning off car Coop Issues | Warranty | Recalls / TSB 7 09-14-2018 02:28 PM
Hissing/ticking sound under load NyX_Nick Engine, Exhaust, Transmission 8 06-05-2018 10:01 PM
Hissing/rattle from 3.5-4k RPM after OFT illmatic_frs Engine, Exhaust, Transmission 28 03-21-2017 09:02 PM
Hissing clutch noise FR-Sky Issues | Warranty | Recalls / TSB 32 02-16-2017 11:57 PM
Hissing from what sounds like front left wheel at 45+ MPH Mattstermh Issues | Warranty | Recalls / TSB 2 07-28-2016 09:29 PM
