Old 08-10-2012, 12:48 PM   #1
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Multi TPMS?
I am going to need at least two sets of tires for this car. I don't want to have the tires mounted/unmounted from one set of wheels, so I will need multiple sets of wheels as well.
If I buy a second set of wheels and another set of TPMS sensors for the second set of wheels, how do I go about switching between the two?
Can I have two sets of sensors 'paired' to the car? If not, do I need to go to the dealer to have the sensors paired every time I change wheels/tires?
-Justin
Justin.b is offline   Reply With Quote
Old 08-10-2012, 12:58 PM   #2
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
I wonder about the same. I have changed to new wheels with TPMS sensor and a get tire pressure warning occasionally, not every trip. Do I have to go to the dealer to fix this?
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 08-10-2012, 01:03 PM   #3
Justin.b
I had read that the dealer needed to mate the sensors to the car.
I'm OK with doing this once per set of wheels (if there's no DIY alternative) but it would become a pain if I had to do it every time I wanted to change between two sets of tires.
-Justin
Old 08-10-2012, 01:53 PM   #4
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Only options are to go to the dealer (or most tire shops), or go out and buy the right tool. I use the ATEQ Quickset tool. It works well and costs about $150.
If you get the ATEQ quickset you need to make sure you get the ID's for the new wheels. It will read the set that are currently paired from the OBDII port but you'll need to manually enter the new set.
Old 08-10-2012, 02:58 PM   #5
Justin.b
$150 is less than any trip to the dealer....
Once you have paired the new TPMS sensors to the car, do they stay paired? Or do you need to un-pair the tires you're taking off and pair the car with the wheels going on?
-Justin
Old 08-10-2012, 09:28 PM   #6
neutron256
neutron256's Avatar
-Justin
You have to re-pair each time you switch wheels. It you're just doing it once go to the dealership, if you're going to switch wheels a lot I reccomend getting the tool.
We use snow tires on both our cars so:
2 cars X 2 times a year = 4 trips to the dealership
Old 08-11-2012, 05:44 AM   #7
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Will it void the warranty?
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 08-11-2012, 07:25 AM   #8
neutron256
neutron256's Avatar
I can't see how it would. There is no way the TPMS system can cause harm to the drivetrain. Tire shops use ATEQ tools all the time.
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 02:22 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 05:24 PM
so what is everyone doing about their tpms? Hachi6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-22-2012 06:04 AM
BRZ at Multi-Subaru, Union NJ today 3/13 grst1 BRZ First-Gen (2012+) — General Topics 7 03-14-2012 02:41 PM
