Old 11-12-2020, 03:51 AM   #1
504
504's Avatar
Drives: 2014 86 GTS
Apparent rich misfire - help
Hi all,
Appreciate any guidance in advance
I've recently developed a highly rich condition with stft sitting at -29.9 at idle with12afr (commanded at 15), I'm beginning to suspect that a ignition coil has failed but not sure how to diagnose this with certainty
For context, it's a ecutek tuned turbo 86, been running great for 4 years, no hardware or software changes to note of late. I am alittle Sus about potential disabling of DTC code so can't check for misfire dtc to confirm, or atleast nothing is popping up when I scan for it
Confident I do not have exhaust or intake leaks which tend to produce positive fuel trims anyways. I was thinking it may be oイ sensor? But it appears to be reading a corresponding voltage to the measured afr, seems like the less likely culprit
What do you guys think?
504 is offline   Reply With Quote
Old 11-12-2020, 05:50 AM   #2
steve99
could be leaking injector
excessive fuel pressure
dirty maf sensor
but just guessing
maybe log some idle with ecutek cable and post up to www.datazap.me
Old 11-12-2020, 12:38 PM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Stupid question probably, but what does your air filter look like?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I知 car. Derp
Count to muffens and call again.
I知 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 11-13-2020, 04:53 AM   #4
504
504's Avatar
Drives: 2014 86 GTS
It's a cone K&n filter sitting inside bumper. I've custom made an enclosure for it, doubt it's the filter to be honest, it's a high flow arrangement
Old 11-13-2020, 10:55 AM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I'm just wondering if it's dirty. Rich conditions on many cars can often be due to a dirty air filter. Not enough air flow for the fuel to burn cleanly. Your ECU sees that and tries to compensate by reducing the amount of fuel. You're turbocharged also, so you're pulling more air through that filter, it's going to clog up faster.
When was the last time you checked and/or cleaned it?
Old 11-13-2020, 09:47 PM   #6
504
504's Avatar
Drives: 2014 86 GTS
Maybe 10,000km ago or so, car is only on 55k km, I would say it stays fairly clean due to the location and the small mods I did around the filter, good idea on that though
Just an update, I have since pulled out 3 of 4 ignition coils and did an ohm test on the pins and they seem to come out good so far. I'll try get the 4th out, and maybe even spark plug if possible.
From my last drive the issues occured on very light load application, i.e. full DI so don't think it's a port injector issue also . Anyone have an idea on which sensor would cause such issues if faulty? Maybe map? Oイ?
UPDATE: MAF looks alittle oily, thanks Steve, map getting cleaned too. I'll report back if this changes anything
Old 11-13-2020, 11:19 PM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
If that K&N filter is one that you oil to help capture dirt and dust, and you found that the MAF sensor that痴 in there to be oily, your air filter could still be the original source of the problem. Is your MAF sensor upstream or downstream from the turbo? If It痴 downstream, and your turbo is also oil-cooled, you might have an issue with oil getting past the seals and spitting it into your throttle body and also onto your MAF sensor. Not sure how your setup is though, but that would be something to look at if the sensor is getting oily.
After you clean your MAF sensor, and if that temporarily fixes the rich condition, after a hundred miles or so of some spirited driving, you should pull the sensor back out and check to see if it痴 oily again. If it is, then you need to figure out where the oil is coming from. The oily and dirty sensor will fool the ECU into thinking that there is more air flowing into your engine than there actually is, which it will then attempt to compensate for with more fuel....up to a point, at which it should then start throwing a code or two.
Old 11-16-2020, 02:53 AM   #8
504
504's Avatar
Drives: 2014 86 GTS
Update to close thread.
Problem solved, appears to be dirty maf and/or map sensor. Car running fantastic now particularly at very light loads
Old 11-16-2020, 09:06 PM   #9
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Good to hear, but keep in mind what I said in my last post. If your MAF sensor gets oily again, there’s a reason.
OFT+OFH running rich Dabrown Software Tuning 14 11-28-2016 04:20 PM
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 02:55 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-26-2013 12:42 AM
Misfire Jono AFRICA 49 12-12-2012 07:01 AM
Rich man's FR-S (WRB BRZ) Hamza7 Cleaning and Detailing 9 06-24-2012 12:36 PM
