Señor Member
Drives: '17 BRZ PP
ACE A350 header Bolts/nuts torque specs?
Hey fellas, yesterday thanks to a bunch of you cool guys I was able to finish installing my ace a350 header. I am doing the heat cycle/retighten method to prevent the hardware from falling off (as the ace headers are so well known for), but I could not find the torque specs for them.
What are the torque values for the header/overpipe nuts, for overpipe/frontpipe bolts, and for header/engine nuts? thanks |
Drives: 2017 toyota 86
Google: “ft86club exhaust torque spec”
Somewhere between "pretty tight" and "plenty snug"
Sent from my ONEPLUS A5010 using Tapatalk |
I think that's 2 ugg Doug's (itsjusta6 reference)
2013 Series 10 FRS #553
Señor Member
Drives: '17 BRZ PP
Well I went ahead and tightened them good'n'tight. After heat cycling the car a few nuts were actually loose, so it's good to know to retighten them. The engine mount nuts in particular were completely loose, which is probably why I heard some clunking noises during logging. The header to OP nuts were also a bit loose, hopefully they stay nice and tight for good.
| Tags |
| a350, ace, specifications, specs, torque |
| WTH Ace A350 Header | ionbomb | Want-To-Buy Requests | 0 | 02-18-2019 11:51 AM |
| FS ACE Header A350 | mtsound | Engine, Exhaust, Bolt-Ons | 0 | 09-14-2018 12:44 PM |
| Overpipe to Header Bolts/Nuts | 808BRZ | Engine, Exhaust, Transmission | 2 | 07-25-2016 09:41 AM |
| torque specs for front and rear subframe bolts | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 06-17-2015 03:54 PM |
| Header torque specs | Triumphrider | Engine, Exhaust, Transmission | 4 | 06-15-2014 11:09 AM |
