Old 01-28-2021, 12:52 AM   #1
K3rbal
Oil Pan Suggestions for a 5.3 LS swap
I was wondering if there was a preferred or a recommended oil pan for this swap that would require minimal modification to the oil pan or cross member where the engine mounts?
I looked over a LS2 swap thread where he mentioned preferring the SIKKY oil pan, or a OEM GTO oil pan. I was curious if there was a more available and possibly affordable alternative to the SIKKY oil pan. This GTO oil pan idea led me to find this JEGS pan for a GTO that looks rather low profile and inexpensive.
I was wondering if anyone had any experience with this topic and could possibly help out. I have little experience with engine swaps, but I have some friends helping me out, they just did not know if there was a "preferred" pan the community has found to work better than others.
Thanks in advance!
K3rbal is offline   Reply With Quote
Old 01-29-2021, 12:22 PM   #2
Icecreamtruk
Drives: Track preped NA FRS
CXracing also makes a pan but it probably only works with their mounts (or is at least specifically made for them). You can buy the pan in their kit with the mounts but not separated from it, so that should be why it is like that.
engine bay, engine swap, fitment, fr-s, oil pan
STI Brembo bleeder swap suggestions??? Front calipers. Hachiroku14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 58 01-24-2022 05:24 PM
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 01:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 03:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Rim suggestions? Perihelion Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-15-2013 03:47 PM
