Drives: 23 GT4RS
SOLD Trd close ratio gear set 1-2, mfactory 6th gear SOLD
SOLD
#2 | |
Drives: M4
Drives: 23 GT4RS
1st and 2nd will be spaced closer together and closer to third than stock. Essentially, rpms will be lower at the same speed as the original gears. The mfactory 6th gear will bring the ratio closer to 5th therefore the rpms will be higher at the same speed as the original gear. I guess this would make these gears shorter since it brings them closer together with a smaller rpm drop when shifting compared to the original ratios.
Take a look at this cusco pdf, since its essentially the same gearset just rebranded: https://www.cusco.co.jp/en/jpg/86%20BRZ%20Gears_A4.jpg |
#4 | |
Drives: M4
Did you ever have it installed? If so, can you hit 60 in 2nd? Sent from my iPhone using Tapatalk |
Drives: 23 GT4RS
Purist
Drives: 2013 FRS - Hot Lava
![]() ![]() 4.1 RATIO DIFF
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
Drives: 23 GT4RS
Bump. Lowering price to 1300 shipped in the USA.
Drives: 23 GT4RS
bump
Drives: 23 GT4RS
bump, still got this
#10 |
Drives: 23 GT4RS
Bump, 1000 shipped, not looking to ship overseas or any forwarding addresses thanks.
#11 |
Drives: 23 GT4RS
bump
#12 |
Drives: 23 GT4RS
bump
| Who wants a TALLER MFactory 6th gear | toast | Engine, Exhaust, Transmission | 41 | 10-05-2020 03:12 PM |
| BRZ 2018 AT to MT gear ratio | Septor | Engine, Exhaust, Transmission | 22 | 01-21-2019 04:42 PM |
| MFactory Final Drives & Close Ratio Gears | YCW | Transmission and Driveline | 0 | 09-29-2016 01:28 AM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 03:40 AM |
