Old 08-05-2021, 01:27 PM   #1
w3bhead
Drives: A Car
Need help with a 17x7.5 +35 offset
Hi guys!
I need help regarding wheels with a 17x7.5 +35 offset. I've been looking at the forums but I can't find any pictures with those wheel specs that show the front view of the car. I wanted to find out how much of the tire wall sticks out of the fender with the +35 offset. Any help/photos you have will be a great help.
Thank you!
w3bhead is offline   Reply With Quote
Old 08-05-2021, 01:45 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
17x7.5 ET35
Subaru camber bolts up front, stock ride height.
No poke at all, I’d say ~10 mm from flush up front with 215 tires
IMO it’s just right for this car
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (08-10-2021), Racecomp Engineering (08-06-2021), Thefalls (08-10-2021), Wally86 (08-06-2021)
Old 08-10-2021, 05:15 AM   #3
Thefalls
Thefalls's Avatar
Drives: Corolla GT
It doesn't poke at all ( 17 x 7.5 ET 35 )
I have 17 x 8 with ET 35 and the fronts are flush almost at stock camber. With some negative camber I'm sure they will be nicely tucked inside.
Thefalls is offline   Reply With Quote
Old 08-10-2021, 02:29 PM   #4
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Here are pics of a couple different cars (including mine) with OZ Ultraleggera in 17x7.5 ET35
https://www.ft86club.com/forums/showthread.php?t=145570
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 08-11-2021, 06:01 AM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
With no camber 17x8 +35 is about flush.
I've run various spacers but settled on 8mm at effective offset of +38. -2° of camber front and rear. The wheel tucks a bit at the top.
To get a flush with 17x7.5 you'd probably need +25, +30. Camber bolts will push the top of the wheel in.
Old 08-13-2021, 05:06 PM   #6
Derka
Drives: 2015 frs
Same car as yoshoo posted. Minor drop added. Oem tire size
Derka is offline   Reply With Quote
The Following User Says Thank You to Derka For This Useful Post:
Yoshoobaroo (08-13-2021)
Old 08-13-2021, 05:10 PM   #7
Yoshoobaroo
TRACKBREAD
Dude I’m loving the things you did. The drop, the brakes, the 86 headlights. It looks amazing!
Old 08-13-2021, 05:39 PM   #8
Derka
Drives: 2015 frs
This is my all time favorite car. I absolutely love it!! Thank you so much for the opportunity
Old 08-13-2021, 06:16 PM   #9
Yoshoobaroo
TRACKBREAD
That’s amazing to hear, so glad she went to someone that really appreciates the car!
Best offset range to use with 17x7.5 wheels? Adam_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-10-2016 05:56 PM
17x7 +30 offset?!?!?!?!?!?!?! Leight1104 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-06-2016 01:07 AM
17x7.5 +40 offset project d CANADA 2 01-17-2014 12:02 PM
Autec Zenit 17x7 40 offset KBRZee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-08-2013 04:39 PM
Let's talk Offset. 17x7.5 +35 Tainen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-28-2012 04:57 PM
