Old 09-17-2021, 02:15 AM   #1
Enigmeerkat
Enigmeerkat
Enigmeerkat's Avatar
Drives: 2015 Toyota 86 GTS
Question Loose Whiteline Swaybar End Links
Hi all,
I've had an issue since my Whiteline Swaybars were intalled, where the front end links will rattle when going over any kind of bump or undulation in the road.
I'm aware that after first install they can need to be re-tightened, but this has happened 4 times now and it keeps coming loose; say within an hour or two of driving. It doesn't hapen to the rears.
Anyone had any similar experiences or could suggest a permanent fix (other than the obvious 'remove the sways')?
Thanks!
2015 Toyota 86 GTS
- Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch
- PSR UEL Header, Invidia R400 Catback
- Whiteline Swaybars, 18" ROH Blue Evo R
Enigmeerkat is offline   Reply With Quote
Old 09-17-2021, 01:14 PM   #2
Veypor
Drives: 2015 FRS
Originally Posted by Enigmeerkat View Post
Hi all,
Thanks!
I had the same issue, use some blue Loctite on the threads and torque them to spec.
Veypor is offline   Reply With Quote
Old 09-17-2021, 01:23 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Get new lock nuts and retorque. You can also try double nutting them, there is plenty of thread there.
Old 09-17-2021, 10:51 PM   #4
Enigmeerkat
Enigmeerkat
Thanks guys, will give it a go!
2015 Toyota 86 GTS
Old 09-19-2021, 11:20 PM   #5
Enigmeerkat
Enigmeerkat
Update: Loctite was already being used, but turns out there is a very slight worn bit on the thread. Have sourced some self-locking 12x1.25mm nuts to try the double-nutting.
Fingers crossed should be all sorted tomorrow.
If not I'd need to get a replacement end link I would imagine?
2015 Toyota 86 GTS
Old 09-20-2021, 04:22 PM   #6
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
My WRX does this with a 24mm bar. Loctite didn't cut it, so I ended up using a second nut on the endlinks front and rear. Probably not the best engineering solution, but it works.
cmiovino is offline   Reply With Quote
Old 10-08-2021, 10:17 PM   #7
Enigmeerkat
Enigmeerkat
Sorry for the delayed update - lockdown has made actually going for a drive and testing it difficult.
Got the extra nuts, put them on, helped the problem a fair bit (like, 80-90%), but not entirely. There was still some weird clunking. Ended up discovering the adjustable height nuts were loose too. Tighetned those all the way up and now finally the problem is fully fixed!
Car feels 100x better now, for the first time since the sways were installed by some dodgy mechanics I will never be going back to!
Cheers for the tips guys
2015 Toyota 86 GTS
WTB: Whiteline Rear Swaybar Links Slade Want-To-Buy Requests 1 07-09-2019 09:03 AM
FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces e1_griego Brakes, Suspension, Chassis 1 02-15-2017 01:00 PM
BC Racing Front Adjustable Sway bar Swaybar End Links - $100 shipped STS-V Brakes, Suspension, Chassis 3 08-31-2014 11:01 AM
Stance USA Front Adjustable Sway bar Swaybar End Links - $100 shipped STS-V Brakes, Suspension, Chassis 3 08-31-2014 11:00 AM
Swaybar hitting control arm - adjustable links enough? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 08-02-2013 10:14 AM
