Drives: '13 FRS
2103 FR-S Flood recovery
Greetings all. Picked up a flood title '13 FR-S this week with full intent of gutting, caging, and LS swap. But when it was delivered today, it's in much better shape than I expected. I might try and get the engine running and try to drive a bit before weather sets in and gutting it.
Battery was charged, ignition came on, even bumped the starter to see if the engine would roll. Not enough juice, so will test the battery and put it on the charger and see from there. The fuse panel cover was off which would seem to indicate someone looking for some sort of problem. I'm not fully convinced the car was written off for flood damage, but maybe something mechanical underlying. I have Techstream and a cable on the way. I used to build BMW motors, but not familiar with these at all. My plan is to do the following while I wait for cable to arrive: - fully charge battery - change oil, cut open filter, inspect for debris - pull plugs and check compression - Pump out all old gas - check for spark to see if immobilizer and ignition system is working Aside from that, anything else you guys would recommend looking at until I can scan it? |
Rust bucket enthusiast
Take the door cards off, pull the carpet oil and remove residual water probably hanging out in there. Change the brake fluid and replace all the fuel as you had said.
My 2013 was a stage 1 flood car and I was lucky, it was perfectly capable after the above
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Generally biggest problem with flooded cars is not mechanical issies but electrical.
As a lot of the electeonics is still powered even when car off, once stuff gets wet electrolysis set in amd many of the plugs and modules that are npt 100% sealed will develop corrosion and in some cases damage modules permanently or even worse intermittent faults. The cars arw full of electronic modules quote a few need to communicate for the car to even start. Your best hope would be a donour car and swap in all the modules wiring loom dash cluster. Unless your lucky amd not much got wet |
Dismember
Drives: 2013 Red Scion FR-S
Steve is wise.
#5 | ||
Drives: '13 FRS
If that ends up being the case, no sweat, my plans were to gut every ounce of interior, OEM wiring, and electronics except ABS and EPS and have a cage built for it. I paid next to nothing for it, so not a loss at all and just would have been a bonus if I could get it working until I have the swap engine, trans, swap package, and Motec gear ready to install. |
Drives: 2023 Toyota GR 86 Cup
Does the engine even turn over? put a 27mm socket and breaker bar on it and see if it is hydrolocked....and get the interior out of it and dry it out pronto.
2023 GR Cup Car
#7 | |
Drives: '13 FRS
Breaker bar on crank and no movement either direction. None. I'm going to be optimistic that if I pull the plugs, it might just be a cylinder hydrolocked, but given these motors are prone to spin bearings anyway, not expecting much from it. Weather should be decent this weekend, will start getting seats and carpet out. |
It's done, get a new motor....
2023 GR Cup Car
Drives: '13 FRS
Kind of what I figured. Talking to a local guy and will probably pick up an L33 this weekend for $500 and a second from LKQ for about $750. I can get the conversion and fab done with it and have a spare motor for cheap.
I've been reading through your first build and leaning towards the HTE-Rs, going to sit in some next week. Do you see any issues with fitting them in full cage? |
#10 |
Drives: '13 FRS
I was able to spend a couple of hours on it today and fully stripped the interior. I don't think there's ever been a trace of water inside.
The more I look at it, the more I'm convinced it was claimed as a flood for insurance when in reality the motor was toast. It looks clean enough, I'm considering just finding and FA20 for it and keeping it streetable even though it does have an auto trans. |
#11 | |
friendly
Drives: 17' 86
I haven't driven one but I would imagine a supercharged auto would be a blast.
Seek comfort in discomfort.
#12 | |
Drives: '13 FRS
Looking around for FA20s, holy crap they aren't cheap. |
#13 |
Drives: '13 FRS
#14 | |
AutoX-10/10ths every run
Yes, they are.
| Scir16v's flood car | Scir16v | Member's Car Journals | 15 | 09-15-2018 12:42 AM |
| Where do you guys keep your recovery tools? | Swagopopotamus | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 07-18-2016 06:01 PM |
| Looking for end of lease FRS/BRZ or theft recovery | Four_wheel_drifts | Northwest | 7 | 06-27-2016 08:01 PM |
| NJ 2103 BRZ Limited, WRB, 14k miles, ESC $23/$25,000 | Gary in NJ | Cars for Sale/Trade | 11 | 10-14-2014 07:21 PM |
