Old 10-05-2021, 02:22 AM   #1
kyu01186
Drives: 2018 BRZ BASE
Exclamation Car cranks but won't start after openflash custom tune install
After installing a base map for a supercharger using open flash. My brz cranked but wouldn't start and threw code P0335. I changed the sensor with a new one and it still didn't fix the problem. When I reverted back to stock the car won't even crank.
Any ideas?
kyu01186 is offline   Reply With Quote
Old 10-05-2021, 08:28 AM   #2
steve99
Any ideas?
After checking battery is good and termials clean and tight see below
My guess would be
Port injectors installed do not match whats scaled in tune
MAP manifold pressire sensor installed doesnt not match whats scaled in tune
The Direct Injection computer the one on side of engine doesnt npt have all tgree mount bolts in and tight, thats its earth, not earth on that module weird stuff happens
Or you have been given an incompatable rom ie manual rom in auto car or pre facelift rom in post facelift car or other way round. That will cause security to trip amd car wont crank.
no crank, no start, openflash, supercharger 86 frs brz, tune
HELP! Cranks but won't start P0102 P0113 Sum10clever Issues | Warranty | Recalls / TSB 2 09-06-2020 12:46 AM
Car cranks but wont start yablonskiy11 Issues | Warranty | Recalls / TSB 15 01-02-2019 01:18 PM
Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas. WinterWolf Issues | Warranty | Recalls / TSB 12 05-26-2018 08:12 AM
Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas. WinterWolf Forced Induction 2 05-16-2018 05:38 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
