Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-07-2022, 02:30 PM   #1
Essex/AP Racing BBK for 2022 available now!
https://www.facebook.com/CounterSpac...3865820007298/
https://www.essexparts.com/my-vehicl...Subaru/BRZ/All
Lookin mighty pretty
Confirmed fitments (355mm):
9660 only confirmed fitments
Factory 18" wheels
9668 only confirmed fitments
Factory 18" wheels with 8mm spacer
Both 9660 and 9668 confirmed fitments:
Forgeline 17" w/ spacer (varies with offset and width)
RAYS 57CR 18x9.5
RAYS 57DR 18x9.5
RAYS 57Extreme 18x9.5
TWS T66-F 18" all variants
Old 01-07-2022, 03:03 PM   #2
ForeverCar
Drives: 2022 BRZ and some other cars
Looks amazing! So awesome!
ForeverCar is offline   Reply With Quote
Old 01-07-2022, 03:08 PM   #3
Yes. Both front and rear kits are available.
Old 01-07-2022, 10:43 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
So many good options. I see the Sprint kit isn't available for the second generation cars. Is that due to the increase in power causing the smaller, lighter rotors to heat check prematurely?
Old 01-07-2022, 11:03 PM   #5
PLF69
Drives: 2020 M340i, 2022 BRZ
It will be available later.
PLF69 is offline   Reply With Quote
Old 01-08-2022, 12:06 AM   #6
ForeverCar
How should one decide 372mm vs 355mm front? Does 372mm push one to 19” wheels?
Of course, I’d like the lightest possible setup that does the job. However, future plans might have some big power & repeated high speed runs so also trying to plan for the future.
Old 01-08-2022, 10:51 AM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
Check out this thread. Specifically post #25:
https://r.tapatalk.com/shareLink/top...ink_source=app
Old 01-08-2022, 12:59 PM   #8
ForeverCar
Thanks. FYI, the link didn’t work for me when using a browser (but I see the thread ID).
Good to know 355mm should handle everything. Let’s see if I can build something to overwhelm it.
Old 01-09-2022, 09:26 PM   #9
wilsynet
Drives: 2022 BRZ
I don’t want to track the car, but I want to save some weight and reduce unsprung mass anyway. And I want them to fit 17x7.5 wheels.
The Essex product pages say various kits fit the factory 18 inch wheels. Do any fit 17 inch wheels?
wilsynet is offline   Reply With Quote
Old 01-10-2022, 01:55 AM   #10
372 won't be necessary for anything but the most extreme builds, imo.
Both 355 and 372 will require 18" wheels for virtually all applications. The only 17" wheel that I know of that is in production that will clear these brakes are Forgelines, which run ~6k/set.
With 18" wheels, most wheels should clear both calipers. Templates are available for both.
If there's enough demand and folks are willing to crowdsource the info as they try it themselves, I'll happily keep a running list going for the next 5+ years. I'll start with what I've already tested.
Old 01-10-2022, 01:55 AM   #11
Unless you're ready to spring for some 17x7.5 Forgelines, you'll need 18" wheels.
Old 01-10-2022, 12:26 PM   #12
ForeverCar
Do you happen to know which style of Forgeline in 17” clears the 355mm 9660? For 18”, I thought there’s a minimum width of 8.5” due to the forging used. 7.5” is available in 17”? That’d be awesome!
Old 01-10-2022, 04:11 PM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
AP Racing Endurance (CP8350/325) and Sprint (CP8350/299) fit the OEM 17x7.5" wheels.
timurrrr is offline   Reply With Quote
Essex/AP Racing Sprint Kit proven in endurance racing by Toyota engineers JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-18-2026 08:37 AM
AP Racing by Essex Brakes for the 2022 BRZ JRitt BRZ Second-Gen (2022+) — General Topics 62 06-10-2024 09:14 PM
AP Racing by Essex Brakes for the 2022 BRZ/GR86 JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-13-2022 09:52 AM
AP Racing by Essex Brakes for the 2022 GR86 JRitt GR86 General Topics (2nd Gen 2022+ Toyota 86) 69 02-14-2022 03:02 PM
RR-Racing Sport Performance and AP-Racing Essex Initial Comparison Gear_One_Performance Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 04-20-2016 05:31 PM
