Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-18-2022, 08:37 AM   #1
KillerBMotorsport
KillerBMotorsport's Avatar
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp
For those that are interested in seeing another dyno plot of the 2022 BRZ here it is. We also installed both oil temp and oil pressure sensors, because that's what we do
The performance was remarkably consistent and made more power than I expected. Our Mustang AWD500-SE reads lower than the average Mustang Dyno, I expected this car to make ~185 at the wheels, but it made quite a bit more.
Interesting to note, the dash oil temp data was higher than what we were reading in the sump by 10-15° and the sump temperatures got cooler with each pull. Ambient temps were in the 60s. We'll likely datalog the oil pressure/temp again in the summer heat and see if the temps drop. For oil, we are running Amsoil Signature Series 0w-20.
For comparison's sake, here is a Gen 1 (tuned) that was run on our dyno a few years ago...
If anyone has any questions, ask away!
KillerBMotorsport is offline   Reply With Quote
Old 04-18-2022, 12:49 PM   #2
OkieSnuffBox
Drives: '23 BRZ Limited
Really seems like Subaru pulled a BMW move and underrated the engine by a decent margin.
Old 04-18-2022, 12:55 PM   #3
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
I can’t see any picture you post
Stonehorsw is offline   Reply With Quote
Old 04-18-2022, 01:20 PM   #4
Ohio Enthusiast
Drives: 2018 BRZ
Are you at work? On VPN? I can see them fine on my personal laptop, but some workplaces block certain image sources.
Ohio Enthusiast is offline   Reply With Quote
Old 04-18-2022, 01:23 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Using safari or an iOS device?
Old 04-18-2022, 01:27 PM   #6
Jianlun
Drives: GR86 RC
Able to post the AFRs in the same plot? Would be nice to see if its rich (because stock safe tune) and thus any potentially possibility to unlock some horses anywhere in the rev range.
Jianlun is offline   Reply With Quote
Old 04-18-2022, 01:34 PM   #7
KillerBMotorsport
I can look. We did log O2...
Old 04-18-2022, 04:34 PM   #8
KillerBMotorsport
Here ya go. I turned the smoothing way down so you could see the AFR correction oscillations.
Old 04-18-2022, 04:35 PM   #9
alphasaur
friendly
Drives: 17' 86
Strong numbers for a mustang dyno.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 04-18-2022, 04:51 PM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Can you please document which oil pressure sensors you install and where?
Aspiring track day data logger here.
Follow the build thread for my GR86!
timurrrr is offline   Reply With Quote
Old 04-18-2022, 05:16 PM   #11
Stonehorsw
Stonehorsw's Avatar
Yes, Safari/iOS
Old 04-18-2022, 05:18 PM   #12
KillerBMotorsport
We use all Omron 0-5v sensors. They are all lab quality sensors. The pressure sensors are -15-to-120psi if I remember correctly.
If you're going to be datalogging with a Motec or something, you'd be using 12v sensors, but I'd reach out to them for recommendations.
Motec Sensors
Old 04-18-2022, 05:33 PM   #13
KillerBMotorsport
Yes, Safari/iOS
Try loading Firefox. Should work
Old 04-18-2022, 06:18 PM   #14
Yoshoobaroo
TRACKBREAD
Yes, Safari/iOS
That's it. Safari doesn't like the Sharepoint links to KillerB's domain.
Unfortunately it only works on Firefox/Chrome on Mac. On iOS there's not a damn thing you can do since all browsers on iOS are a Safari reskin.
High Flow Oil Pickup by Killer B Motorsport KillerBMotorsport Engine, Exhaust, Bolt-Ons 4 04-26-2022 10:51 AM
If you post a dyno plot, please, include what the fuel was used. Calum Forced Induction 1 10-12-2015 07:59 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 07:09 PM
