Old 04-30-2022, 12:20 AM   #1
repillows
Drives: 2013 Scion Frs
Power steering not working with a C1528 code
As the title states, my power steering quit working and is showing a current code of C1528 which is motor rotation angle sensor. This issue was mostly intermittent but has recently been happening a lot. I tried unplugging the harnesses going to the power steering ECU with no luck, and looking at live data, the rotation angle is all over the place and is showing little to no amps to the motor. The vehicle had an alignment issue with the power steering working when I bought it but then stopped. I replaced the struts, control arms, and steering rack to fix the alignment issue thinking that the power steering issue was related but it was not. Has anybody experienced this issue or has any insight as to what to do? Thanks!
repillows is offline   Reply With Quote
Old 05-11-2022, 10:45 AM   #2
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
My first recommendation would be to have the Steering Ange Sensor recalibrated; this should be done anytime an alignment is performed so any good alignment shop (or the dealer) should be able to do it. If that doesn't correct the issue, follow the service manual steps below;
DTC C1528 MOTOR ROTATION ANGLE SENSOR
DESCRIPTION OF FUNCTIONS
As part of the fail-safe function, power assist is suspended when a motor rotation angle sensor malfunction diagnosis code is being output.
DTC No: C1528
Detected item: Motor rotation angle sensor malfunction
Inspection parts:
• Motor rotation angle sensor (integrated into the steering column ASSY)
• Power steering computer ASSY
CIRCUIT FIGURE (See Picture #1)
INSPECTION STEPS
CAUTION:
Always perform a steering zero-point calibration after replacing the steering column ASSY or power steering computer ASSY.
1. Check the connector connection
(See Picture #2)
(1) Check the connection state of motor rotation angle sensor connector z2.
Criteria : The motor rotation angle sensor connector is properly connected to the power steering computer ASSY.
Is Connector connected (Power steering computer ASSY)
IF NG >Connect it securely
IF OK▼
2. Read the SSM3 data (motor rotation angle)
(1) Use the SSM3 to check the [Motor Rotation Angle]. (Refer to )
SSM3 screen: [Power Steering] → [Current Data Display & Save]
(See Picture #3)
Criteria : During engine start and steering operation, this varies between 0 - 360 deg.
IF NG
> Go to Step 3.
IF OK▼
Replace the power steering computer ASSY
3. Inspect the steering column ASSY (motor rotation angle sensor)
(See Picture #4)
(1) Disconnect the motor rotation angle sensor connector z2 from the power steering computer ASSY.
(2) Measure the resistance of the vehicle side connector.
Resistance
Inspection terminals Inspection conditions Standard value
z2-5(RZV) - z2-7(RZG) Always (23°C) 27.6 - 41.4Ω
z2-14(RZSN) - z2-7(RZG) Always (23°C) 75.2 - 112.8Ω
z2-13(RZCS) - z2-7(RZG) Always (23°C) 73.6 - 110.4Ω
*a
Front side of vehicle wiring harness connector (Power steering computer ASSY connector)
IF NG
>Replace the steering column ASSY
IF OK▼
2023 GR Cup Car
Opie is offline   Reply With Quote
Scangauge oil temp xgauge code [Working] pkny Engine, Exhaust, Transmission 125 12-26-2022 12:11 PM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 06:27 PM
Power steering not working RyanOlsen05 BRZ First-Gen (2012+) — General Topics 12 09-18-2021 03:54 AM
Power steering failure and code issues RyanOlsen05 Scion FR-S / Toyota 86 GT86 General Forum 1 09-18-2021 01:46 AM
Power steering C1528 code owenxguo Issues | Warranty | Recalls / TSB 2 08-05-2016 02:30 PM
