Old 10-03-2022, 10:05 PM   #1
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
2022+ camber thread
Hey all. I kind of wanted to start this thread for a while to gauge what people are running for camber/toe on the new model since we have less body roll, and it would be nice to gather data on what people run for their setups. The only factor we cannot account for is the drivers skill-set, but that aside, it'll assist the community to get a feel of what others are running. I know there are a lot of threads on this already, so I am trying to consolidate, and I'll post what I can find from others in other threads.
if you can follow the format, that would be much appreciated:
Code:
 Car:
 Wheels/tires:
 Springs/shocks/coils:
 Function?/looks?:
 DD/Canyon/Track:
 Driving experience:
 Other suspension mods:
 Camber/Toe:
 (optional) thoughts/opinions:
I'll go first.
Car: 22 BRZ limited
Wheels/tires: TWS T-66f 18x8.5 +42 / Michelin Pilot Sport 4S's 245/35r18
springs/shocks/coils: CSG spen tein flex A's (as DD, I do 8 clicks front, 11 rear)
function?/looks?: function
DD/Canyon/Track: DD, canyon sprints mostly, maybe 2-4 track days
Driving experience: intermediate. Still learning the car. 2 HPDE events
other suspension mods: SPC rLCA's, Subaru STI Flexible V-bar, rear toe arms.
Camber/Toe: -2.0f -1.5r, 0.1 toe inwards in the rear.
(optional) thoughts/opinions: this was my initial setup, and I think I might push it a bit more. Recently I did a trip up the PCH on highway 1 and the 101, and once I got comfortable with the car with no one on the road, I started to gently test a bit, and noticed I am getting oversteer and the back is kicking out first in the corner. admittedly, I do prefer that anyways, and I am loving the car so far. I dont know if i'll push the camber more due to me DD'ing it to work.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 10-03-2022, 10:08 PM   #2
Daedex
That One Guy
Daedex's Avatar
placeholder
Old 10-04-2022, 01:31 AM   #3
gcmak
gcmak's Avatar
Drives: GR86
Car: 22 GR86 Premium AT
Wheels/tires: Enkei TS-10 17x8 et45 / Hankook R-S4 225/45/17
springs/shocks/coils: 2nd gen CSG Tein Flex A (16 clicks f/r for driving to/from track and typically around 5 clicks front and 4 clicks rear for HPDE)
DD/Canyon/Track: HPDE
Driving experience: ~20 HPDEs
other suspension mods: SPL RLCA
Camber/Toe: -3.2F, -2.5R / 1/16 total front toe-out and 1/16 total rear toe-in.
(optional) thoughts/opinions: I would use the CSG recommended f/r damper settings if i were to drive spiritedly on the streets instead of just to/from the track and random errands just to keep the car moving. The suspension and alignment are really quite nice on track with great turn-in, stable mid-corner, and settles over bumps nicely.
gcmak is offline   Reply With Quote
Old 10-04-2022, 03:12 PM   #4
8/11 s very much a comfort setting. Add rebound in the back and the rear will get more settled. Try 7/7 in the canyon, and then further adjust to taste. As you already know, clicking all 4 dampers is a very quick process of just popping the hood and/or trunk, and clicking as needed.
7/7 for daily driving will be on the firmer end, but you may find you prefer it when the mood strikes.
The best part is that you can change your setting to suit your mood in under 15 seconds.
Old 10-04-2022, 04:35 PM   #5
Daedex
That One Guy
Daedex's Avatar
Yeah, I should have clarified, That’s what I use to putter around. On the PCH for the twisties, I did 6 clicks front, 8 rear. Hella nice.
Old 10-14-2022, 03:23 PM   #6
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Car: 22 BRZ Premium
Wheels/tires: Enkei TS-V 17x9 ET45 (10mm spacer up front) / Yokohama Advan A052 245/40R17
Springs/shocks/coils: Shaftworks USA with 6k/9k Swift springs
Function?/Looks?: Function
DD/Canyon/Track: DD, Autocross, Occasional HPDE/TT
Driving experience: Advanced, lots of Solo Nats trophies & ProSolo championship, a few TTs and a bunch of HPDE
Other suspension mods: Karcepts front swaybar, Subaru crash bolts, Moog camber bolts in OEM RLCAs, Whiteline diff & subframe bushings
Camber/Toe: -4.5 Front -2.5 Rear Camber, 0.00 Front 0.30 Rear total toe-in
Thoughts/Opinions: I need -0.2 more camber at both ends of the car, I could use a little bit of front toe-in to keep the inside shoulders of my tires happier for DD.
Rides pretty well, handles great, looks great... when I'm not on my winter/stock setup.
Old 10-14-2022, 03:44 PM   #7
strat61caster
strat61caster's Avatar
I’ve heard toe out helps with camber wear in the front, not in? Seems to help a bit for me at 4.3 degrees.
ineedyourdiddly
Old 10-14-2022, 04:37 PM   #8
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've experienced both. I tried some toe-out and it seemed worse
Old 10-14-2022, 05:37 PM   #9
marco_mc22
Drives: Toyota 86
How’s the car with those rates? Are you on stock diff?
marco_mc22 is offline   Reply With Quote
Old 10-16-2022, 05:36 AM   #10
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
Car: '23 BRZ Premium
Wheels/tires:
On APEX 17x9 +35 / +42 F/R wheels:
Hoosier A7/R7 245/40/17, or Z214 245/40/17
On stock wheels:
RT660 225/45/17
450 #/in (78 N/mm), 550 #/in (96 N/mm) MCS 2WNR
Stock sway bars.
DD/Canyon/Track:
Track (HPDE) use.
Driving experience:
HPDE Advanced, Instructor, etc.
Rear UCAs and toe links.
Camber/Toe:
-4.2 / 0 toe / 6 degrees caster front, -2.5 / 0.15 degrees Toe (in) rear
As I'm building this car for HPDE use, tested out these coilovers for the first time at the track, today. With Karcepts' recommended settings (minus their sway bar), the car felt very soft and a bit bouncy. Their settings are 2 / 6 comp/rebound front, and 3 / 7 rear. It felt a lot more stable after +1 rebound and +4 compression all around. I should probably add a bit more rebound, but did not want to mess with it as I was testing out other things as well (e.g. new pad material).
Does the Karcepts sway bar make a significant difference in your experience?
What spring rates do you guys use for HPDE only track duty? The springs I have with recommended settings felt very soft, and I wonder if I should seek stiffer springs, or just compensate with higher compression and rebound; tough to figure it out without knowing much about this platform : )
From yesterday..
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
Old 10-17-2022, 02:07 PM   #11
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Stock diff. Rates seem great. Puts down power way better than I had expected and it's balanced *really* well with 1/4" of rake (rear higher than front) measured hub to fender.
Wheels/tires:
On stock wheels:
RT660 225/45/17
Stock sway bars.
DD/Canyon/Track:
Track (HPDE) use.
Driving experience:
Camber/Toe:
From yesterday..
I think you need a little softer front spring (400 lb/in?) and way more front swaybar to fix the softness. If you're not going to be constantly going to different tracks or messing with car setup in changing conditions, the Karcepts bar is overkill. I love the Karcepts bar for autocross because every site is different but if I was building for solely HPDE I'd just do a Perrin 19mm or 22mm (maybe buy both in case you want to swap)
The MCS shock settings seem pretty reasonable from what I know of Karcept's MCS 2WNR valving. I've seen folks run as high as 10 clicks of compression though, so you definitely have room to play with the shocks.
Old 10-17-2022, 05:22 PM   #12
X25
X25's Avatar
Perrin's 22mm bar is pretty comparable to what Karcepts suggested for front sway bar stiffness, so I suppose I can just go with that.
What do you think about the rear bar? In other platforms, only (substantially) upgrading one end introduced stability issues on road course track. Per their web site, Perrin seems to recommend 19mm rear bar for a stiff road course setup paired with their 22mm front bar.
I'm not sure why you suggested softer front spring; I've had excellent front bite to be honest, and considering how soft it feels at times, I can't imagine using even softer springs?
Old 10-17-2022, 05:59 PM   #13
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I like stock rear bar or softer and use spring rate instead. Keeps wheels planted better with stock diff.
IME with my 6k/9k spring rates, going higher than 2/2 on the Karcepts swaybar makes the car pretty much a dump truck with my A052s on asphalt or worn in track surfaces. The Falken RT660s make the car even pushier. On concrete or fresh racetrack grade asphalt, I can get away with like 3/3 or *maybe* 3/4 on the swaybar.
Old 10-23-2022, 07:18 PM   #14
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
I picked up a car that already had Karcepts MCS 2WNR w/ 400F/500R springs.
I've finally settled on this for sporty driving:
Front:
7 rebound / 4 compression
Rear:
9 rebound / 4 compression
Camber:
-3.5 F / -2.x R
Karcepts front bar on 2/2
This is with 17x9 Michelin PS4S in 245/40 @ 28psi. I still haven't made it to the track yet, but I doubt I will change it much there. Maybe a tad more rebound.
I really struggled to tame undulations with this setup. High speed shock movements like potholes and bumps are fine. Minor imperfections in the road can cause the car to jitter vertically. Letting a bunch of air out of the tires and bumping up compression helped.
Wheels/tires:
On stock wheels:
RT660 225/45/17
Stock sway bars.
DD/Canyon/Track:
Track (HPDE) use.
Driving experience:
Camber/Toe:
From yesterday..
Wangspeed is offline   Reply With Quote
camber, suspension, toe
STX setup sharing thread (2022) Autoxer62 Tracking / Autocross / HPDE / Drifting 204 06-15-2023 03:34 PM
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 06:13 AM
2022+ BRZ STi Parts and Accessories Thread. WorldRallyB BRZ Second-Gen (2022+) — General Topics 162 08-20-2022 12:47 PM
2022+ Exhaust compilation thread Yoshoobaroo Engine, Exhaust, Transmission 22 04-22-2022 07:17 AM
2022 BRZ Dealer Stock Tip Thread slipstream8 BRZ Second-Gen (2022+) — General Topics 12 12-06-2021 10:45 AM
