Old 11-07-2022, 12:18 PM   #1
BRChelz
BRChelz
Drives: 2015 Subaru BRZ Limited
Post Fuel issue with 2015 BRZ
Hello, I have a 2015 manual BRZ that I can’t let the gas fall below 1/4 of a tank or I loose engine power (like literally it just doesn’t go and I’ve had to limp it to a gas station, I also will not get a low fuel light to indicate when I’m out of gas bc I can’t let it get that low. I’ve also had it have a hard time starting unless I let it prime for like 20 seconds. Is this a high pressure or low pressure fuel pump issue possibly? Anyone else experience this before? I’m not the original owner so I don’t know if they had tried to E85 swap this car, I always put 91, please help!
BRChelz is offline   Reply With Quote
Old 11-07-2022, 12:33 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yes, you have an issue with the low pressure fuel pump. If it has been that way since you've owned the car, the previous owner may have messed with it. Take it to a shop.
Old 12-25-2022, 02:49 PM   #3
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
I wish people would come back with their fix.
CB750F is offline   Reply With Quote
fuel, fuel issue, fuel pump, gas tank, starter
Intermittent fuel issue Bihv BRZ First-Gen (2012+) — General Topics 4 11-11-2022 01:05 AM
Fuel pump issue? Please help!!! kmbkk Engine, Exhaust, Transmission 5 04-22-2017 11:53 AM
Fuel Cut issue SupraFly85 Mid-Atlantic 4 10-19-2013 11:30 PM
Idle issue then Fuel Cut SupraFly85 Issues | Warranty | Recalls / TSB 4 10-19-2013 11:26 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 10:57 AM
