Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Engine, Exhaust, Bolt-Ons
Old 11-17-2022, 02:27 PM   #1
Ansix Auto
FT86Club Official Vendor
Drives: 2023 BRZ
2022+ BRZ/GR86 Oil Pan RTV Solution - Ansix Auto
This is Ansix Auto’s solution to the RTV issue that’s been affecting all Toyota GR86 and 2022+ Subaru BRZ FA24 motors. Owners have been finding RTV blocking up their oil pick up tubes. The RTV comes not only from the oil pan, but from the sealing of the timing cover and the block halves. Since the RTV can break off at any time, dropping the oil pan once to clean out the pick up may not be sufficient long term as more RTV can break off at a later date. Our solution is to add a port to the oil pan to allow for inspection and clean up of the pick up at every oil change interval.
Modified Oil Pan with Inspection Bung
We take brand new oil pans and weld in an inspection bung at the correct location to inspect and clear out the oil Pickup.
The bung is designed to sit flush inside the oil pan and also not protrude too far down to be the lowest point in the car. Each pan is individually vacuum leak tested. Once the pans are welded, they are sent out for a Cerakote Glacier coating. This high temperature ceramic coating provides and extra thermal barrier to reduce the amount of heat transfer for the nearby exhaust to the oil via radiation and convection.
RTV Vacuum tool
The vacuum tool allows our customers to make use of their shop vacuum to suck up the RTV from the oil pickup tube via the installed drain port. The tool is designed to allow the suction to be pulsated rapidly to generate turbulence at the oil pickup to loosen the RTV from the strainer and suck it away. The included mesh allows you to collect the RTV for inspection.
Oil Pan baffle
The Ansix Auto baffle offers a few advantages over it’s competitors. Firstly, our baffle is designed to have a tight fit in the recessed lip of the block. Other baffles have a gap all the way around which can allow oil to slosh up past the baffle making it less effective. Secondly, our baffle has it’s doors oriented with the direction of the lateral oil movement. This means that under cornering, the direction of flow will push the doors shut and also allow oil from the opposite end to drain down more readily. Finally, our baffle does not add any additional sealing surfaces. Some baffles are bolted through using the oil pan bolts. This doubles the required sealing area and leaks could be more likely.
Kit with Oil Pan included - $850
https://ansixauto.com/products.php?p...howHidden=true
Weld in kit (modify your own pan) - $250
https://ansixauto.com/products.php?p...etCurrencyId=2
Ansix Auto is offline   Reply With Quote
Old 11-28-2022, 06:02 PM   #2
Ansix Auto
Drives: 2023 BRZ
Bump! We have 3 modified oil pans left from this first batch.
Check out our GR86 and BRZ products!
https://ansixauto.com/subaru/
GoPro Mount - Ansix Auto Ansix Auto Interior Parts (Incl. Lighting) 7 04-30-2025 01:51 AM
2022+ BRZ/GR86 CANbus Adapter - Ansix Auto Ansix Auto Audio/Visual, Electronics, Infotainment, NAV 11 07-04-2023 05:01 PM
Element Fire Extinguisher w/ Mount - Ansix Auto Ansix Auto Interior Parts (Incl. Lighting) 17 01-17-2023 04:20 PM
San Diego: 2022 GR86 OEM Premium GR86 Rims GRime86 Wheels and Tires 3 12-10-2022 05:52 PM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-13-2022 12:44 AM
