Old 11-27-2022, 02:04 PM   #1
Tornike
Drives: 2018 subaru brz
Abs from 2013 year model brz/frs to 2018 year model brz
Hello, does anyone know if abs pump module from 2013 year model frs/brz is compatible with 2018 year model subaru brz? And is re-programming required when you change abs pump module?
Tornike is offline   Reply With Quote
Old 11-27-2022, 03:58 PM   #2
RedReplicant
Drives: None
It would work with a repin, but you are best off buying a 2017+ module that matches your transmission.
The 2013-2016 units had different / more intrusive traction control modes.
RedReplicant is offline   Reply With Quote
Old 11-28-2022, 11:35 AM   #3
Tornike
Thank you, they cost way too much than previous models. Do you know what pins should be changed?
Old 11-28-2022, 01:36 PM   #4
RedReplicant
Drives: None
https://www.ft86club.com/forums/showthread.php?t=140946
You would probably do the inverse of this
Old 11-29-2022, 02:24 AM   #5
humfrz
Couldn't cost any more than you slamming into something because your car's brakes aren't working.
Old 11-29-2022, 10:40 AM   #6
Grady
Grady's Avatar
The cost of replacing the ABS module with the correct one is a known cost. The cost of replacing the ABS module with an earlier one is unknown. The part may be less but the time to get it to work and possibility of mistakes and issues are greater. Are you only looking at new or have you searched for used?
abs, brz, frs
Which model year to look for? Rkcs Scion FR-S / Toyota 86 GT86 General Forum 80 01-29-2021 11:59 PM
Car Model Year different in ROM. Atomicarchitecht Software Tuning 2 05-23-2019 06:52 PM
Later model-year differences? Qwimby1 Scion FR-S / Toyota 86 GT86 General Forum 22 07-14-2018 11:05 AM
Report: 6000 BRZ coupes for 2013 model year! ahausheer BRZ First-Gen (2012+) — General Topics 90 03-18-2012 07:43 PM
