Old 01-31-2023, 06:34 PM   #1
crowbar_combat
crowbar_combat's Avatar
Drives: 2018 BRZ Premium
ECU Permanently stuck with different CALID after ECUFlash tune?
I have a 2018 USDM manual BRZ, meaning it had the CALID N10C from the factory.
I flashed a WayneROM K00G tune using the appropriate definition and a Tactrix Openport, mistakenly assuming that I could easily flash it back to my original tune if I wanted to.
Unfortunately, it seems there isn't a working N10C definition available anywhere. The ROM and definition I found from this thread do not actually match and the tables are clearly horribly wrong in EcuFlash. Therefore, I can't restore my ECU back to an N10C CALID.
I would like to get my car professionally ECUTek tuned, and I'm concerned that my CALID not matching what it was from the factory is going to cause issues. Do I need to tell the tuner about this as soon as I purchase a tune? Is there a working N10C definition I just failed to find?
Thank you
crowbar_combat is offline   Reply With Quote
Old 01-31-2023, 11:36 PM   #2
makinen
makinen's Avatar
Drives: Toyota 86
No need to get an exact definition to write down an image.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 01-31-2023, 11:57 PM   #3
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Just make a flash only definition as per the thread below
https://www.ft86club.com/forums/showthread.php?t=62332
There is also a stock N10C romm attached in that post as well
AussieBRZ is offline   Reply With Quote
Old 02-01-2023, 03:39 PM   #4
crowbar_combat
Appreciate it guys, I will give the flash only definition a try.
ecuflash, tactrix
OFT Tune Stage 1 - Question Regarding CALID Tunes / Definitions and Changes to maps YwllowFox Software Tuning 8 07-25-2023 04:29 AM
EcuFlash gets stuck at 0% when reading flash me2000000 Software Tuning 5 11-23-2021 08:20 PM
OFT Tune Stage 1 - Question Regarding CALID Tunes / Definitions and Changes to maps YwllowFox Scion FR-S / Toyota 86 GT86 General Forum 3 10-22-2021 07:54 AM
Ecutek won't let me flash edited tune, calId differences brosifSmith Software Tuning 2 05-16-2019 07:13 PM
Custom tune with Ecutek and CALID question stlgrym3 Software Tuning 3 06-17-2018 05:18 PM
