Old 04-10-2023, 12:40 AM   #1
Eazy-V
How many 2013 FRS still running without doing valve spring recall
Just wondering how many 2013 FRS are out there still running without doing the valve spring recall? I bought my 2013 brand new and have held off on doing the recall since I only have 25,000km on it, but wondering if I should just have it done.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 04-10-2023, 02:45 AM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Don't do it.
Originally Posted by humfrz
I'm old and lazy
Old 04-10-2023, 11:48 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
the recall was specifically because subaru's metal supplier was caught rubber-stamping entire batches of metal as compliant with subaru's specifications. so subaru really has no idea if the metal is correct or not. but they erred on the side of caution and issued the recall to protect themselves from the fallout of the potential that the incorrect metal was used to make the valve springs, which could lead to fracturing springs.
my personal inclination is that most of the metal was likely close to the correct formulation, with a strong possibility that it might not have met subaru's specified standard, but well within what most other automakers would use for the same components.
i guess the question is "what makes you feel luckier?" ****ing around in a factory-sealed motor that relies on a human tech laying down multiple specific-size beads of caulk to properly seal it, all the while risking damage from taking it apart and putting it back together again, or leaving it and hoping the metallurgy of the springs is correct?
Old 04-10-2023, 11:52 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Hoping that the metallurgy is correct because I'd make the argument that if they were going to fail, they would've failed by now.
I'm old and lazy
Old 04-11-2023, 10:55 PM   #5
soundman98
soundman98's Avatar
correct. we also don't know how stringent subaru's original specifications are compared to typical standards.
could've just as easily gotten the new guy that over-specs everything. who knows, maybe even the 'inferior' version is just what gets sold day-in/day-out to kia.
Old 04-11-2023, 11:08 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
If you don’t need to do it for registration then don’t do it. It’s a Russian Roulette recall.
Old 04-11-2023, 11:12 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
3
Exactly 3.
Thanks again Mr. Owl.
Old 04-12-2023, 11:47 AM   #8
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Never done it....if a valve spring fails in the future, it'll still be covered...
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 04-12-2023, 12:41 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mines still alive. If it was going to break a valve spring it would have done it a long time ago.
Old 04-12-2023, 07:58 PM   #10
Eazy-V
Thanks for the replies and I agree, it doesn't seem worth doing it now. Also since my FRS is modded, I think dealers will either charge me extra due to the mods or will only accept my car once I remove the mods (ie turbo etc).
I'm curious if the dealer will actually give you the recall bag of parts, so you can have it for yourself if you ever need parts down the road ie rebuilding engine etc? I doubt it lol, but wonder if they'd do it if you sign some waiver.
Old 04-13-2023, 03:20 AM   #11
humfrz
Welp, my 2013 FRS falls under the spring recall.
However, I have decided not to have it done.
It has about 35,000 miles on it, it's not modded and I drive it easy.
My take is that iffen it ain't broke by now - don't break it.
Old 04-13-2023, 12:24 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As far as mods, it really depends on the dealer. Some will say yes, there is a thread now with a turbo car that the dealer did the recall on, some will say no.
https://www.ft86club.com/forums/showthread.php?t=152946
They won't just give you the parts, they need to complete the recall repair. Or "repair" in this case. For S&G I asked my local dealer what if my car has aftermarket valve springs and they just looked at me like I asked them solve 4564534.4567/5456143.4567 without a calculator.
Old 04-13-2023, 02:52 PM   #13
Opie
Opie's Avatar
As per the recall instructions, the dealer must complete the recall at no charge. If the car is not stock, the dealer can charge the actual labor time that at is added due to the modifications.
The dealer is not able to give you the recall parts, however, you may be able to purchase them.
2023 GR Cup Car
Old 04-13-2023, 04:32 PM   #14
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Mine, 94k miles
Sent from my motorola one 5G ace using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
2013 Turbo FR-S Valve Spring Recall uDasBoot Issues | Warranty | Recalls / TSB 26 02-21-2022 09:42 AM
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 07:21 PM
2013 Scion FR-S Valve Spring Replacement Recall Aussie Northern California 29 06-22-2020 02:51 AM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 08:03 PM
*California* 2013 Valve Spring Recall Ankleguy Issues | Warranty | Recalls / TSB 14 09-30-2019 12:55 PM
