Old 10-15-2023, 10:42 AM   #1
RichUK
Drives: Toyota GT86
Axle shaft stuck in hub
I'm tying to change my rear wheel bearings, passenger side came apart easily enough, but on the drivers side the axle shaft is stuck in the bearing. I've tried a puller, a sledge hammer, heat, penetrating oil, the works. It's not moving.
Any ideas on where to go next with this?
RichUK is offline   Reply With Quote
Old 10-15-2023, 10:48 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
big prybar with a big hammer?
sometimes, more violence is the answer.
Old 10-15-2023, 10:51 AM   #3
RichUK
Drives: Toyota GT86
The end of the axle is already pretty deformed, I'm not even sure it's saveable at this point, but I don't really want to keep hitting it.
Old 10-15-2023, 06:50 PM   #4
whataboutbob
AutoX-10/10ths every run
Make sure you remove the wheel speed sensors from the knuckle first so you don't damage them, speaking from experience.
Build thread:Here
Old 10-15-2023, 10:35 PM   #5
Spairo
Drives: 2013 FR-S 6 spd in Halo
I used one of these:
OMT Front Wheel Hub Puller Flange Type Tool for 3-3/4 to 4-1/2 Inch IDs, Universal Hub and Axle Puller with 5/8"-18 Forcing Bolt and Sleeve, FWD Hub Installer and Remover Tool with Socket https://a.co/d/3eC0iln
on a very stuck driver's side axle. I used lot's of penetrating oil and cranked down as much pressure on this puller as I dared. I would then smack the end of the drive screw with a large ball peen hammer. After a smack or two, I would crank as much as I could on the tool, maybe a 1/16th of a turn at most. I would walk away for a while (1/2 hour) and then return and repeat, max pressure, smack with hammer, tighten more. At some point I went to bed with the tool in place and under pressure. The next, after a couple more smacks, the screw turned 1/8th of a turn. At that point, I rapidly repeated tighen and smack with each cycle turning the tool more and more until it all came loose.
The whole thing was frustrating as hell, but got me out with deformation or other complications.
Go fast, take chances.
Spairo is offline   Reply With Quote
Old 10-16-2023, 06:29 AM   #6
RichUK
Drives: Toyota GT86
That's more or less what I've been trying amongst other things - I've actually managed to peen over the end of the puller through hitting it though so it'll barely take a socket. I'm going to try a hydraulic puller next I think.
Old 10-16-2023, 07:23 AM   #7
cueball89
Drives: 15 Impreza
I've used this on stuck brake rotors, never had a stuck axle though. If that doesn't work removing the hub with axle and pressing it out may be an option. A 50/50 mix of acetone and ATF fluid is a penetrating mix I sometimes use in difficult situations. Anecdotal but I've removed some ball joint pinch bolts that I thought I would have to drill out.
https://www.harborfreight.com/5-ton-...7&gad_source=1
cueball89 is offline   Reply With Quote
Old 10-16-2023, 02:23 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by cueball89 View Post
I've used this on stuck brake rotors, never had a stuck axle though. If that doesn't work removing the hub with axle and pressing it out may be an option. A 50/50 mix of acetone and ATF fluid is a penetrating mix I sometimes use in difficult situations. Anecdotal but I've removed some ball joint pinch bolts that I though I would have to drill out.
^^^ this ^^^ If you intend to reuse the shaft, spin the nut over the end to keep from mushrooming it.
Old 10-16-2023, 02:24 PM   #9
RichUK
Drives: Toyota GT86
I got a very similar puller today, rated to 15 tons, and cranked it to max. The bearing is free, it fought the whole way out. So I guess than answer was more force.
Rear Axle is stuck in diff neroman98 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-26-2018 02:45 PM
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) Lefty-FRS Transmission and Driveline 13 02-09-2018 11:02 PM
Cam Shaft Control sw20kosh Engine, Exhaust, Transmission 3 03-02-2017 08:23 AM
OEM drive shaft Baramzisyan Transmission and Driveline 13 03-22-2014 04:25 PM
Axle Exchange 1-Piece Alumimum Drive Shaft -- Groupbuy 86_ZN6 Groupbuys 15 10-25-2013 07:44 PM
