Old 01-30-2024, 08:30 PM   #1
Alfrz
Drives: 13 Scion Frs
Headunit needs 'filler' behind it, what can I use?
Bought a new headunit, fits flush in its placement, but the stock brackets/bracket it came with won't help/fit.
What can I do that's a simple diy to the unit stay in place?
1st pic you can see in the top right, how there's extra space
2nd pic is with the unit pulled forward, but obviously even touching it causes it to fall back, since it's basically just temporarily balanced there
Also if you have any idea what I'm supposed to do w this red cord that's attached to the fan, that'd be helpful.
edit: was just missing the brackets, im an idiot. lmao
Alfrz is offline   Reply With Quote
Old 01-30-2024, 08:47 PM   #2
Make sure you can't adjust the brackets foward, which will move the unit back. If that doesn't work you should be able to fabricate some fairly easily.
NOTE: I can't tell for sure from the photos but I'm assuming the HU is sticking out to far. If it's recessed too far, just reverse what I said.
Old 01-30-2024, 10:04 PM   #3
Alfrz
Nah I should've explained the pics a little more.
The first 2 pics, if you look in the top right corner where the trim meets the unit, (straight above the right knob) you can see what's going on. The unit can't stay *forward* enough*.
Not at my car rn, but are you saying the stock brackets may be movable?
Old 01-31-2024, 12:33 AM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
When installing many standard-sized DIN or double DIN aftermarket head units, you would normally remove the side brackets from the OEM head unit that you removed from your dash, and install them onto your new head unit. The new head unit you have in the pictures does not appear to be able to have those side brackets mounted to it. Did it come with its own special brackets that you are supposed to use instead? Maybe I just can't see due to the angles of the pictures.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I知 car. Derp
Count to muffens and call again.
I知 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-31-2024, 04:36 AM   #5
Alfrz
Lol thanks, never swapped a headunit before, didn't realize I had to remove the bracket off the oem, tbh dunno if I even realized it there was one there. It's all fixed and flush now
Old 01-31-2024, 07:34 AM   #6
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Did you wire up the fan and attach what appears to be a loose ground?
dragoontwo is offline   Reply With Quote
Old 01-31-2024, 09:23 AM   #7
may be movable?
Sounds like @FR-S2GT86 was able to help you out, but yes most aftermarket headunits I've ever put in allowed for multiple attachment points of the stock bracket and usually some fine adjustments.
Old 01-31-2024, 01:56 PM   #8
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Yeah, sometimes you have to get little creative in the installation process. My next suggestion was going to be shims behind the mounting tabs to bring the unit forward a bit, along with possibly using some longer mounting bolts if needed.
I'm also guessing that the fan power supply should have been plugged into one of the receptacles on the back of the unit.
Old 01-31-2024, 03:34 PM   #9
Yeah, sometimes you have to get little creative in the installation process. My next suggestion was going to be shims behind the mounting tabs to bring the unit forward a bit, along with possibly using some longer mounting bolts if needed..
It is definitely more art than science if you want it "just right". I need to replace the aftermarket bracket in our Suburban because the one that came with the kit tends to slip in one corner for some reason, and the unit is always lower on the left corner. Probably a 15 minute fix but the unit works and I don't think about it unless i'm driving it somewhere.
Old 01-31-2024, 05:40 PM   #10
Alfrz
So... I did not. Wanna explain that part like I'm 5?
Old 02-01-2024, 03:59 AM   #11
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
If you don't connect it to a power source, your head unit will probably overheat. I suspect it is there to cool the internal amplifier. Did that head unit not come with an owner's/operator's or installation manual? In the very last picture, I can see on the label that your unit is possibly designed for use in a Corolla. Perhaps in the Corolla there is a specific receptacle already in the dash that it needs to plug into.
If you could supply us with some more information, it would help us to help you. Brand and model of unit, used or new, oftentimes when you pick up something second-hand the manuals don't get transferred with it in the process.
Old 02-01-2024, 01:29 PM   #12
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
To me, the fan appears to have previously been plugged into the 4 pin slot pointed at by the red lines on the fan housing.
Mostly because of the existing bends in the loose wires.
Then again, those two arrays also look like monolithic plugs with locking arrangements.
Would be a good thing to find the manual to go with the head unit though before depending on random internet advice.
Oil filler cap came off - oil all over - help indio22 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 09-15-2021 04:42 PM
BRZ headunit problem USB sticks & headunit reset..school me. Photonic Electronics | Audio | NAV | Infotainment 2 03-12-2014 07:06 PM
Grimmspeed Oil Filler Cap SilentMike Engine, Exhaust, Bolt-Ons 3 10-07-2013 11:37 AM
For Sale: TRD Oil Filler cap Panman Australia Classifieds 4 04-13-2013 08:22 PM
Fuel Filler is on the Right!! Guaruja Scion FR-S / Toyota 86 GT86 General Forum 43 04-01-2012 06:55 PM
