Old 05-05-2024, 08:26 PM   #1
1234eher
Drives: 2014 FRS
Question Did I do something bad? Knocked key into "Start" position while driving
Keeping a long story short, while driving accidentally pushed the key into the "Start position" (the position furtherest clockwise, like cranking to start the car) while driving. My 12V accessories like dashcam, phone charger, and headunit rebooted. Didin't hear any nasty noises or anything. Could there have been any damage? what are the consequences of this?
Couldn't find anything in the manual, trying to learn. Thank you in advance.
1234eher is offline   Reply With Quote
Old 05-06-2024, 12:16 AM   #2
humfrz
Just don't do that no more -
Well, that won't be the first time someone has tried to "start" a car that is already running.
Back in the day, about the worst thing that would happen is that one would have ground a little metal off the starter gear and flywheel. Comments from bystanders might have been "grind me off a pound".
If your car's starter works fine after that, I wouldn't worry about it. If it don't, you might have to have the starter replaced.
Old 05-06-2024, 12:29 AM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
In cars back in the day, when you turned the key, you actually engaged the starter. In modern computerized cars, all you do is ask the computer to please start the car. Computer knows the car is already started... No damage.
Old 05-06-2024, 01:09 AM   #4
1234eher
Drives: 2014 FRS
No noise, car started right up without issues. Definitely not a habit.
Nice to see that you're still around on the forums OG.
Old 05-06-2024, 01:12 AM   #5
1234eher
Drives: 2014 FRS
Thank you for the information!!! learning as I go.
I was scared of the flywheel and starter the most. But this is a good explanation of why I didn't hear any noise or experience RPM fluctuation. only my accessories restarted, dash was still illuminated and uninterrupted.
Old 05-06-2024, 01:23 AM   #6
humfrz
Good information.
Answer me this about new cars. mrs humfrz's new vehicle (Honda CR-V) has a start button. Now, it also has this pesty feature that shuts the engine down when idling then starts back up when you hit the gas.
Now, while the engine is in this "rest" mode, what would happen if one would hit the start button again?
Asking for her, since she won't let me drive her new car -
TIA
Old 05-06-2024, 09:20 AM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Good information.
TIA
I have no idea. I've never had a car with the start/stop "feature".
Old 05-07-2024, 10:13 PM   #8
Dake
Dake's Avatar
Good information.
TIA
Can't speak for the CRV, but in the RAV4 if you hit the start/stop button again, it will shut the car off (or into accessory mode) but tell you to put it in park. Just try it when you are pulled off to the side of the road and see what it does.
You may be able to go into the CRV's settings and turn off start/stop altogether if you really don't like it. Barring that, just quickly releasing and then stepping on the brake usually gets the engine to fire up and it typically won't kick off again for a few minutes.
Dake is offline   Reply With Quote
Old 05-08-2024, 01:04 AM   #9
humfrz
Thanks for the info.
If mrs humfrz catches me punching ANY buttons on HER new vehicle, I'll have hell to pay -
Yep, the CR-V has a button on the consol that will disable the start/stop feature. However, it resets to default when the engine is shut down. I reach over and punch it when she ain't looken -
Old 05-09-2024, 11:36 AM   #10
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Keep in mind too, the starter won't engage unless the clutch is pushed in. the safety switch saved you.
Old 05-09-2024, 11:39 AM   #11
blsfrs
blsfrs's Avatar
Sometimes, just for fun, I push my wife's buttons.
Old 05-09-2024, 12:46 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Today I learned that some Twins have keys.. I was thinking it was fobs for all...
Old 05-09-2024, 01:22 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yep, only a key here, no button.
How about cars that have both key and button!?
Old 05-09-2024, 02:17 PM   #14
humfrz
I do that sometimes, just looking for the "mute" button. Besides, there ain't nutten dirty with the flannel shirt I'm wearing, just because it has a little oatmeal dribbled on it..
help please, question, troubleshoot
Tesla "Full Self Driving" not capable of autonomous driving AnalogMan Other Vehicles & General Automotive Discussions 241 03-17-2023 01:36 PM
Camshaft Position "A" Help Relogical Issues | Warranty | Recalls / TSB 10 07-30-2020 07:55 PM
CEL P0020 - "A" Camshaft Position Actuator... raul Issues | Warranty | Recalls / TSB 5 11-28-2017 04:55 PM
CEL P0020 - "A" Camshaft Position Actuator... raul Tracking / Autocross / HPDE / Drifting 7 09-25-2017 04:01 PM
Car doesn't start, multiple "clicking" when trying to start tracerit Issues | Warranty | Recalls / TSB 22 01-27-2017 03:56 PM
