Drives: 2016 Scion FR-S(Halo)
Please help, Weird Sound After Clutch Replacement
Hey guys,
Yesterday I picked up my car from the auto shop after having the clutch and flywheel replaced with new OEM parts, along with fresh transmission fluid. Since getting it back, I’ve noticed a weird noise when I quickly get on the throttle at higher RPMs. It doesn’t happen every time, but fairly often — usually when I’m in gear around 3,500 RPM and press the gas quickly, I hear a sort of “chh” sound. The sound it hard to explain, almost the the sound of scissors cutting. And I don’t know if I’m going crazy, but I feel like the exhaust startup sound is a bit muffled. Any ideas what this could be? https://imgur.com/a/BkKg03O |
Drives: 2016 Scion FRS Release Series 2#439
Did you follow any break-in procedure for the new clutch?
I installed an aftermarket clutch which included explicate first 500 mile break-in instructions. Basically gentle behavior which was fine as I was also breaking in a new built short block.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#4 | |
But my concern is the sound that I hear when I stab the throttle, usually at higher rpm in gear. |
The Dictater
Drives: '13 Red Scion FRS
Hard to tell from the video, but mine has done something like that from day-1, 13 years ago. For me, it's the throttle pulling in a bunch of air quickly, like breathing in through pursed lips. Not sure if yours is different or if you are just now noticing.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
Rust bucket enthusiast
This is what I was thinking. Maybe the shop caused a change in the intake and OP is now hear the brief intake noise almost all of my cars
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Hmm, you could be right. I initially thought that it might be something with the exhaust, and they didn’t properly tighten the bolts etc. but it doesn’t happen every time.
The Dictater
On mine it usually happens when rev matching a downshift. You can always have someone blip your throttle while you stand next to the open hood to try to localize the sound.
| Weird noise after starting the car after a stop | Resions | Issues | Warranty | Recalls / TSB | 4 | 04-17-2022 04:39 PM |
| Weird Sound From Clutch | sma96 | Issues | Warranty | Recalls / TSB | 18 | 11-29-2021 11:16 AM |
| Strange sound after exhaust install, please help identify. | pr086 | Engine, Exhaust, Transmission | 22 | 12-24-2017 11:39 PM |
| Weird sound when throttling after foot is off the pedal | VincentN | Issues | Warranty | Recalls / TSB | 7 | 10-23-2017 12:16 PM |
| Weird Sound After Coilover Install (when moving steering wheel left and right) | taimysho0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 07-20-2013 02:18 AM |
