| Engine Swaps Discussion of engine swaps. |
Drives: gt86
Custom Wiring Harness Cable Length
Hi Forum!
I am currently in the process of building my first wiring harness for a engine swap project. Unfortunately i cannot physically mount the engine in the car yet - but i want to finish as much as possible before i rent a space to do the swap. I plan to locate the ECU/PDM under the dashboard Firewall Passenger Seat. Can anyone recommend me a cable length from ECU to Cranksensor. The Cranksensor on my Swap-Engine is the first sensor closest to the firewall - right behind the transmission adapter - approximately 10cm away from the firewall. And approximately same height as the stock fa20 clutch cylinder - I would measure all the other cable lengths from there. But how long should the cable be form ECU to Cransensor? - where did you drill a whole through the firewall? I understand that this question is a rough estimate - pictures of your cable routing would be highly appreciated too... Maybe sbd has some recommendations... Best regards Christoph |
Drives: 2013 frs base
Are you doing a F24 swap or something else?
Drives: gt86
no - i am working on a M138/F136 swap
Drives: 2018 FA24 SWAP BRZ "ANNIE"
Sadly, there is no correct answer other than telling you to wait until you get the engine in place so you can finalize the routing, avoiding fuel lines, etc. Without having the engine and all the other things in place like the fuel lines, etc. you are 100% wasting your time. You will either make them too short or too long.
The only other option would be to make a bulk head connection at the firewall to finalize your routing inside the car, but you would still need to have everything in place to route the wiring in the engine bay.
DJ
2008 MX-5 PRHT "Violet" 2018 FA24 Swap BRZ "Annie" |
Drives: gt86
Hi - well as soon as i have determined how long the cable to the cranksensor is - the first sensor after the firewall i can measure all the other connectors from there. It is a fairly simple wiring harness - i only want to controll the engine - for now i am planning 120cm from ecu through firewall to cranksensor - potentialy too long /depending on where i make the hole through the firewall - have you got any experience on how long this measurement is on average ? BR C
#6 | |
Drives: 2013 Subaru BRZ Turbo
The more I read this thread, the more I wonder what your actual starting point is. Do you have a rolling chassis without any wiring or something? |
Drives: gt86
i know that the cranksensor of my new engine i gonna swap in is very close to the firewall - i am only planning to controll the engine - no other funciton of the factory ecu - i believe if you keep the std. ecu/engine harness you can recover various functions too like abs and power assisted steering - but if not than i don t care too much - so ya my pdm is gonna control next to ignition the fuel pump and the radiator fan and thats it
#8 | |
| WTB: BRZ or 10 series/monogram 8 pin connector + length of wiring harness | NahumCC | Want-To-Buy Requests | 4 | 02-18-2016 06:08 PM |
| TOMEI HEADERS EXPREME UNEQUAL LENGTH / EQUAL LENGTH AND JOINT PIPE FOR FRS/BRZ | myjdmparts | Groupbuys | 85 | 10-07-2015 03:17 PM |
| Subwoofer wiring length | alvinrenz | Electronics | Audio | NAV | Infotainment | 2 | 07-06-2015 03:09 PM |
| ?equal length or unequal length headers? | subaruferrucci | Engine, Exhaust, Transmission | 22 | 07-11-2013 01:56 AM |
| Wiring harness | sastexan | Electronics | Audio | NAV | Infotainment | 0 | 06-17-2012 12:41 AM |
