Old 08-29-2012, 01:11 AM   #1
Hanakuso
Drilling a Hole for Tow Hook or License Plate
I made a small DIY for creating a hole for either a tow hook or license plate holder, such as my Grimmspeed license relocation kit.
I take no responsibility for any damages that occurred. Do it at your own risk.
Tools needed:
1. Plastic trim remover or a flat screwdriver. I wrapped a flat head screwdriver with electrical tape.
2. Drill and 7/8 Spur-point drill bit. 1 inch or bigger drill bit will allow for more error if you messed up on measurements or you have a thicker tow hook or license plate holder.
3. Ruler
4. Paper/Cardboard
5. Wrench to remove and install tow hook or license plate holder.
6. Grommet (optional)
7. Spare tow hook cover (optional)
Steps to make the hole correctly.
1. Remove the tow hook cover with either your plastic trim remover or flat head screwdriver.
2. (Optional) Buy a spare tow hook cover just incase you mess up or want to keep the original for later. I bought mine from the local dealership for $20 painted.
[IMG]http://i2.photobucket.com/albums/y42/kikim85/3C0***A0-E650-42A1-9169-0C54FE4673CF-4830-000005DAF859ABF6_zps5a0b405a.jpg[/IMG]
3. Insert the tow hook or license plate bolt you intend to use. Don't attach the rest of the license plate kit since you want room to make measurement.
4. Measure the top, sides, and bottom from where the tow hook or license plate bolt to the end of the tow hook area. It's not in the middle of the cover so it's crucial you get this done correctly.
5. Get your paper or cardboard and outline the edges with a pen/pencil. Now use your measurements and test it on the paper/cardboard. It took me 2 tries and I had to keep cutting extra pieces off to make it fit on my test paper.
6. Lay the paper directly on the tow hook cover and use your spur-point drill in the middle of the circle. Go slowly since the plastic can melt.
7. Install the tow hook cover
8. You can add a grommet if you want or if you end up using a smaller bolt it can accommodate the extra space around the open area.
9. Install the tow hook or license plate and you're done!
Hanakuso is offline   Reply With Quote
Old 08-30-2012, 03:33 AM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 11-24-2012, 08:40 PM   #3
sinigang_guy
sinigang_guy's Avatar
Drives: argento frs; 90 mustang gt
wanted to say thanks. i also put a 1/8 vacuum hose, cut along the length and placed around the drilled hole.
it gives it a cleaner look on the outside.
sinigang_guy is offline   Reply With Quote
Old 11-26-2012, 04:49 PM   #4
Hanakuso
That looks good. The vacuum hose looks easier to use. The gromment IMO has a better fit/finish but it seems you have to be exactly right with the sizing
Old 11-28-2012, 06:27 PM   #5
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
I never thought about a grommet. Good idea!
-Zach
RallySport Direct is offline   Reply With Quote
Old 12-08-2012, 07:12 PM   #6
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
i never knew you needed a hole. i checked the grimmspeed site and it says "no drilling required"
Dispect is offline   Reply With Quote
Old 12-08-2012, 07:24 PM   #7
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
You don't need to drill at all, but if you don't want the big hole from the cover you remove to install the tow hook license plate holder, then this is a handy DIY to use.
Freeman is offline   Reply With Quote
Old 12-25-2012, 02:21 AM   #8
tonytduc
tonytduc's Avatar
Been looking for this diy thanks!
tonytduc is offline   Reply With Quote
Old 02-11-2013, 04:09 PM   #9
robo_robb
robo_robb's Avatar
Drives: Whiteout FR-S
Thanks a bunch Hanakuso! Could you tell me what kind of grommet you used in this pic?
robo_robb is offline   Reply With Quote
Old 02-11-2013, 04:24 PM   #10
Hanakuso
Just typical rubber grommets. You can get them at lowes/home depot. If you want skinnier ones, I find the selection at computer stores(online) to be better
Old 02-14-2013, 04:23 PM   #11
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Thanks for the DIY! I went out to local Toyota and found part number SU003-01522 as the number for the Hot Lava color. Good looks with the grommet/tubing. I will use the idea for the tubing on a corner I need to protect from rubbing for another project on my 240z, thanks sinigang guy!
Eric G
mkiisupra is offline   Reply With Quote
Old 02-14-2013, 09:36 PM   #12
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
I will contribute to this rather than making a new thread. For the BRZ do the same method but since the surface is not painted, it is a little easier to use a different tool. I actually went with a dremel stone circular bit and pushed at high RPM. It melted the center but kept the outside cool and with a clean cut.
Ended up with this:
Took some wet sand paper to the edges afterwards and looked super clean. Trick is to not get it hot enough so it creates plastic goo. At that point you may end up making a hole bigger than intended. Go low then work up to fast. You start seeing some goo, then back off on the speed and let it cool for a second.
The same bit from above will work too. Just remember drill from the backside of the piece for a clean finish.
I have no "sealed" the hole I made in the tow hook cover door but will probably use some kind of rubber hose and cut down the center.
Old 10-02-2013, 04:25 PM   #13
Shindig
Drives: 2013 FRS
I just did this with a rotary tool and a 3/4 inch grommet from home depot (~$1). I used a couple cardboard templates to get the hole positioning just right. Afterwards, I drilled the hole and expanded it till it could fit the grommet.
I was surprised at how much cleaner it looks. The hole didnt bother me at all, but I figured I could do this project pretty quickly and easily. After finishing, I don't know how I lived with that gaping hole for so long...
Shindig is offline   Reply With Quote
Old 10-02-2013, 08:52 PM   #14
Hanakuso
Your install looks very clean! I might end up doing exactly the same as you.
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 01:06 AM
My new license plate Techknowfile Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 08:57 AM
Tow-hook license-plate template? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 5 06-24-2012 01:51 PM
Delete driver01 Scion FR-S / Toyota 86 GT86 General Forum 17 03-28-2012 01:32 PM
