Old 08-29-2012, 08:44 PM   #1
Mister_Sir
Mister_Sir's Avatar
Drives: 2013 Scion FRS
A few questions before making purchase
I'm debating on getting either a 8.25" wide wheel or a 9.75" wheel to put the stock 215/45/17s on. I really want the wider setup.. but is that too much of a stretch for the stock tires? (Offset is 25mm)
Also what is the lug thread? I need to buy tuner lugs. 12 x 1.5??
Mister_Sir is offline   Reply With Quote
Old 08-29-2012, 09:05 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
12x1.25
8.25" should be fine, 9.75" would look ridiculous especially with that low of offset.
example 10" +30 wheel
http://www.ft86club.com/forums/showt...ighlight=18x10
JoeBoxer is offline   Reply With Quote
Old 08-29-2012, 09:15 PM   #3
Mister_Sir
Mister_Sir's Avatar
Originally Posted by JoeBoxer View Post
12x1.25
Yeh that is pretty extreme. I do want a little bit of poke/flushness. SHould I get the 35mm offset? I just think there would still be a lot of tuck in the rear.
Old 08-29-2012, 09:20 PM   #4
JoeBoxer
JoeBoxer's Avatar
I would say 8.25 +35 front and rear, throw a 10mm spacer on the back if neccessary.
Old 08-29-2012, 09:28 PM   #5
DoctorBomb
Drives: 2013 Subaru BRZ / 1992 Toyota PU
9.5 +35 came out pretty flush on mine (slight poke in the front, slight tuck in the rear with natural camber drop).
Since you are planning on using stock tires, I'd say just get the 8.25s and a spacer in the back to like JoeBoxer recommended.
DoctorBomb is offline   Reply With Quote
Old 08-29-2012, 09:31 PM   #6
xwd
Someone tried putting the stock tires on a 17x9 rim and they wouldn't bead up. I'd say even 8.25 would be pushing it.
Old 08-29-2012, 09:47 PM   #7
Mister_Sir
Mister_Sir's Avatar
What if I purchased 2 +20offset wheels for the back and 2 +35offset wheels for the front?
Would that be weird to buy that way?
Old 08-29-2012, 09:54 PM   #8
JoeBoxer
JoeBoxer's Avatar
They may be hard to sell if you plan to upgrade in the future but other than that should be ok.
Old 08-29-2012, 10:00 PM   #9
Mister_Sir
Mister_Sir's Avatar
true. I settled with all 4 at the +20 offset. I like the beefiness in the front and flushness in the back. It shouldnt look too bad. I'll have pics up here when I get them installed. Thanks for the help everyone
FRS making forcing dealer BRZ discounts. feldy BRZ First-Gen (2012+) — General Topics 36 07-14-2012 11:22 AM
Making Your FR-S Perfect... Lonewolf Scion FR-S / Toyota 86 GT86 General Forum 126 01-03-2012 04:30 AM
GT86 making it's way here to Singapore ! sazu ASIA 1 12-08-2011 10:38 PM
