Old 08-30-2012, 11:43 PM   #1
zooki
Drives: waiting on a 2021...
Rear camber adjustment options?
So what are the options available for adjusting the rear camber on the BRZ/FR-S? I know Whiteline makes an adjustable bushing kit, anything else? Either current or in the pipeline? I thought I saw Eibach may be coming out with something?
zooki is offline   Reply With Quote
Old 08-30-2012, 11:54 PM   #2
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Cusco and few others offer Rear control arms with adjustment...that and the rear is very ride height dependent on Where it would be for camber..
Scooby South is offline   Reply With Quote
Old 08-31-2012, 12:11 AM   #3
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Xanatos is offline   Reply With Quote
Old 08-31-2012, 05:38 AM   #4
eight08customs
Drives: FRS PROJECT
Send a message via AIM to eight08customs
http://www.gtspec.com/product/gtspec...aru-12-brz-frs
eight08customs is offline   Reply With Quote
Old 09-06-2012, 08:38 AM   #5
SpeedmasterBRZ
Drives: Pearl BRZ Limited
SPC makes a rear control arm that is super easy to adjust. I have owned several differant brands on my 09/11 STi and they were the easiest.
Yes, they are listed for a 08+ STi/WRX but they share the same rear control arms.
http://www.spcalignment.com/componen...AFrom&to=USATo
Also if you are interested:
http://www.ft86club.com/forums/showthread.php?t=16641
SpeedmasterBRZ is offline   Reply With Quote
Old 09-06-2012, 11:59 PM   #6
michael317
michael317's Avatar
Drives: BRZ Limited
Originally Posted by eight08customs View Post
i am using the gt spec rear camber arms, if you are thinking of getting that you might want to get the rear toe adjustment arm as well. make the person who is doing the alignment job easier. well not sure how much stock and adjust toe wise with the camber adjusted. I have both and i did the alignment myself and it took a while. i have rear camber set at -2.6 but i think i will be running -3 in rears. if you are planning to get it make sure to have a specialist that know what they are doing to install it.
here is a pic of the arm adjustment parts apart
michael317 is offline   Reply With Quote
Old 09-07-2012, 01:10 AM   #7
gmookher
drool...
gmookher is offline   Reply With Quote
Old 09-07-2012, 01:38 AM   #8
Synack
Boosted
Synack's Avatar
Drives: Sideways
Good lord. I only paid $150 total for both of my rear camber arms including the bigger bolts on my 370Z. What a ripoff we've got currently.
Sent from my Nexus 7 using Tapatalk 2
Old 09-07-2012, 02:44 AM   #9
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I agree. Not much out there and the prices are outrageous. I mean to get a setup that allows good adjustment we are currently looking at a grand if you want front camber plates, rear control arms, and the whiteline rear bushing camber bolts while your in there.
digital_assassin is offline   Reply With Quote
Old 09-07-2012, 05:32 AM   #10
BRZranger
I considered rear camber arms, but right now I'm at -2.5 degrees in the rear, which appears to be w/in spec.
I also considered roll center adjustment, but I just got my alignment...
BRZranger is offline   Reply With Quote
Old 09-07-2012, 11:15 AM   #11
Synack
Boosted
Synack's Avatar
Drives: Sideways
I believe the maximum in spec is -1.75 in the rear. At 2.5 you will definitely see the inside parts of your tires wear substantially faster than the middle. You won't even notice any wear on the outside. That is unless you are tracking the car of course.
Old 09-07-2012, 01:29 PM   #12
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Don't want to spend $500 for adjustable arms so I'm making my own...
I'll start a thread next week when I make some progress...
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
Old 09-07-2012, 01:33 PM   #13
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
After lowering my car on KWs I wound up at -1.9 on one side and and -2.0 on the other.
Old 09-07-2012, 06:15 PM   #14
RavSpec
Drives: Rx7
There are alot of features on GTSPEC that are not available through SPC/Eibach or even the cheapo made it urself camber arms.
To list a few
1. Up to -6 degree camber
2. Camber joints are CNC cut out instead of normal stamp out.
3. It's made out of chromely steel and spray down with anti rush protection coating to prevent rush during the winter where salt and weather will rush regular steels.
4. GTSPEC also made the toe arms to work with the camber arms. Toe arms will be needed if more camber needed.
RavSpec is offline   Reply With Quote
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 11:17 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 06:01 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
