Old 09-01-2012, 12:12 PM   #1
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
Front Rotor Specs - specs found
Anyone of the top of their minds point me in a direction. REally dont want to take the wheel off. pretty sure its been done before.
mostly interested in diameter and thickness. in cm.
I tried searching, and rotor and diameter keywords bring u nothing useful
njccmd2002 is offline   Reply With Quote
Old 09-01-2012, 01:51 PM   #2
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
http://forums.nasioc.com/forums/show....php?t=1265631
JimmyMac is offline   Reply With Quote
Old 09-01-2012, 01:55 PM   #3
JimmyMac
JimmyMac's Avatar
Google is your friend...
Old 09-01-2012, 02:11 PM   #4
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by JimmyMac View Post
Nice informative link.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 09-01-2012, 08:52 PM   #5
njccmd2002
Toyota Freak
njccmd2002's Avatar
i know how to google, and thank you for helping me find the information on the rear rotors.
But i still need to know the front rotors specs...
Old 09-01-2012, 11:30 PM   #6
JimmyMac
JimmyMac's Avatar
Fronts are 11.6 inch... so I'm guessing 295x25.5mm. The rears being 11.4 inch.
Old 09-01-2012, 11:35 PM   #7
JimmyMac
JimmyMac's Avatar
But don't quote me on that because I'm also seeing a reference on 292mm size.
Old 09-01-2012, 11:59 PM   #8
JimmyMac
JimmyMac's Avatar
Mine measured 24mm thickness with my digital calipers. So 294mm x 24mm? Or the 292mm reference on the BRZ?
Old 09-02-2012, 05:14 PM   #9
jamal
jamal's Avatar
Drives: Legacy GT
Well they are close enough that I usually consider them the same thing, especially when you are looking for aftermarket parts. Subaru does have both sizes, with the 294mm rotors going on the WRX and 292mm rotors going on the Legacy. There are some slight differences in construction between the two (Legacy rotors have a little more material in the disc) but they are interchangeable. I think Stoptech/centric is the only aftermarket company that distinguishes between the two: The 294mm wrx rotor is 12x.47018 while the legacy uses 12x.47021
As you can see, not very different although the 021 rotor is heavier. If you are looking to buy some stoptech/centric rotors, most places are going to only have the wrx parts in stock and I'm not sure if they make as many variations of the Legacy rotor (drilled/slotted/125 material etc).
Also I just updated that post linked to add some more BRZ/FRS info.
jamal is offline   Reply With Quote
Old 09-02-2012, 08:51 PM   #10
njccmd2002
Toyota Freak
njccmd2002's Avatar
thanks for your reply, i also found some info on dba australia, similar to posted above. they have an online catalogue
Old 09-02-2012, 11:31 PM   #11
JimmyMac
JimmyMac's Avatar
Scion specs call for 11.6" rotors for the fronts and 11.4" for the rears. The specs in the FR-S shop manual says 24mm thickness. So I think the question is, are BRZ and FR-S front rotors different? 11.6" is about 294.6mm. 292mm would be 11.5". But the 2mm or so difference is very minimal. The important thing is that it's 24mm thick.
Old 09-03-2012, 02:58 AM   #12
jamal
jamal's Avatar
Drives: Legacy GT
no difference. just conversion error/marketing optimism/whatever.
BBS LM (specs unknown) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-08-2014 04:43 PM
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 11:41 PM
HELP! Asian Specs BRZ Lucky13 BRZ First-Gen (2012+) — General Topics 8 09-02-2012 09:26 AM
Does anyone know the front and rear track specs? spiller Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-21-2012 09:25 AM
BRZ CDN specs up at Subaru.ca! Sport-Tech CANADA 17 04-05-2012 10:12 PM
