Stock FR-S/BRZ shock dyno & stock FR-S spring dyno
I'm working with a shop to develop some stock shock replacement options and went ahead and sent them a stock FR-S suspension which they are now working on modeling.
I actually have a BRZ and will be sending them a set of BRZ springs next week, so where it says BRZ on the charts, it's really OE FR-S. As of now I haven't heard of any differences between the dampers of the two cars, just the springs, and of course the dampers will be changed. The shock dyno looks very similar to the OEM WRX ones I've seen in the past. FR-S/BRZ shock dyno: ![]() FR-S Spring dyno:
Drives: '13 BRZ / '11 Outback / '06 Tundra
That's pretty consistent with the FRS rates here:
http://www.ft86club.com/forums/showthread.php?t=10416 |
Had a set of BRZ springs tested as well. Pretty much spot on fron the other threads with the specified spring rates. I don't have the dyno plots for the shocks but they were basically identical.
The data matters
Drives: WRBP BRZ
Thanks for the data, I love data.
Are the front springs progressive? What explains that bump in rate right at an inch to 1.5? |
Drives: Scion FR-S/ Subaru BRZ
the shock dyno makes sense...... my impression on track at the limit in my bone stock FRS is its under rebound damped....looking at the chart you can see it with a maximum 250lbs rebound, but fighting almost the same in springs....
My rebuilt race shocks have nearly 250lbs of compression and almost 500lbs of rebound....much more controlled over bumps even with 800lb springs |
Great thread thank you will serve as a serious baseline for doing any suspension tuning.
Just to note, the shock dyno matches what the dyno we posted on our Facebook and on here a while back very well.
- Andrew |
#8 | |
#9 | |
#10 |
Drives: Nissan Versa
A bit of a necro-bump but I stumbled upon Tein's shock dynos for the FR-S and BRZ.
http://teinusa-blog.com/fr-s-or-brz/ http://teinusa-blog.com/wp-content/u...FRS-Front1.pdf http://teinusa-blog.com/wp-content/u...-FRS-Rear1.pdf |
#11 |
PROUD OF BOXER
Drives: Raven FR-S
noob question alert:
what does this dyno represent? are the stock dampers over damped or under damped? are these dyno representative of a "quality" valve design?
#12 | |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
You would need to pick a system input based on what road load you are concerned with, develop a corner model with the sprung and unsprung masses, spring rates, damper forces (comp and reb), and based on your input event, you may also want to include the sway bar rate, and that will tell you how the system will react... over/under/critically damped. With that said, OE cars are pretty much exclusively slightly underdamped. As far as how the graphs look, I assume this dyno is designed to remove gas force since the graph starts at "0", and I assume rebound force is negative on the graph. Overall, the curves look good as far as not having any defects, and on a sample size of 2, the graphs track very consistant left to right. They are digressive, which is expected from an OE damper (some poorly designed aftermarket dampers can have a progressive damping force if the valving is improperly designed). They appear to be very simple units, nothing fancy at all, basically as you'd expect. Are there Koni Sport graphs posted anywhere??
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#13 |
Drives: '13 UM86
What do these charts tell me in relation to springs rates? Is there any correlation? I am learning...
| Dyno Day @ WGP | Doug@WGP | New England | 56 | 11-09-2012 12:30 PM |
| Dyno Day @ WGP | Doug@WGP | NY / NJ / CT / PA | 5 | 09-21-2012 07:42 PM |
| extended DDPR stock FR-S Dyno testing | Illusive | Engine, Exhaust, Transmission | 5 | 08-26-2012 11:20 AM |
| My fr-s on the dyno | doriNIGHTS | Engine, Exhaust, Transmission | 12 | 06-25-2012 08:32 PM |
| BRZ on the dyno | Symbiont | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 05-22-2012 02:17 PM |
