Old 09-09-2012, 03:56 PM   #1
Hbomb
Drives: Scion Fr-S
Trunk will not open
Trunk will not open. Tried the Key Fob and the Interior button. Any advice?
Thanks
Hbomb is offline   Reply With Quote
Old 09-09-2012, 03:58 PM   #2
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Use the key in the fob. Then when trunk is open push little button on left side in trunk. You've somehow defeated the trunk opening.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 01-10-2013, 09:54 PM   #3
Failscalator
Drives: Subaru BRZ Limited, Silver
I'm having the same issue, i heard a pop while driving so no idea what that was about and ever since the thing wont open even with the key in the slit, no idea what to do other than take it to a dealer.
Failscalator is offline   Reply With Quote
Old 01-10-2013, 10:33 PM   #4
fistpoint
Drives: Supercharged Golf Cart
This has to be the most common error with these cars. There is another post from a new guy right above yours too, how did you miss it with an almost identical title?
fistpoint is offline   Reply With Quote
Old 01-11-2013, 10:53 AM   #5
Failscalator
I didn't miss it man, I used the key, and the trunk still wont open. That's what I tried stating in the above post.
Old 01-11-2013, 11:00 AM   #6
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Not the Fob. The physical key. There's a key hole on the underside of the trunk lid near the license plate.
Grimlock is offline   Reply With Quote
Old 01-11-2013, 11:15 AM   #7
2pt5RS
Berz
There's a button on the left side of the trunk that you probably accidentally pressed. This will deactivate the trunk opening unless you use the key, just like Grimlock stated above. Open the trunk, look on the left side and you'll see the button. It's been covered here many many many times before.
2pt5RS is offline   Reply With Quote
Old 01-11-2013, 11:21 AM   #8
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
If your physical key won't open the trunk, the next thing to try is to pull on the rear seat backs hoping they will fall down. Once down you can reach/crawl to the back of the trunk and pull the green emergency release handle.
If that doesn't work the next step is to jimmy/pry the lock.
If that doesn't work, abandon the trunk as a loss.
If that doesn't work, dynamite.
Then post a picture.
b.e is offline   Reply With Quote
Old 01-11-2013, 11:28 AM   #9
bakerr6
Drives: 2013 raven black fr-s
haha we've all had this problem
follow instructions above. Once the trunk is open, look towardst eh driver's side and you will see a small button. Push the button to turn the trunk unlock feature back on
bakerr6 is offline   Reply With Quote
Old 01-11-2013, 11:29 AM   #10
whataboutbob
AutoX-10/10ths every run
Don't forget the sawzaw just before the step abandoning as a total loss. If you get to the dynamite step be sure to take video.
Build thread:Here
Old 01-11-2013, 11:30 AM   #11
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
This blargeflargen button. This is gonna be like the driving light button that used to be on the top of the steering column of most suby's.
Beyer Subaru is offline   Reply With Quote
Old 12-25-2013, 08:38 PM   #12
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Owned the car for 18 months and it just happened to me tonight for the first time. Had to search the forum for the answer. Thanks to all that posted the solution. An inexpensive design change to put a cover over the button would solve the problem going forward. Just sayin'
davesrave is offline   Reply With Quote
Old 12-25-2013, 11:01 PM   #13
humfrz
......duck tape .........
humfrz
Old 12-26-2013, 12:09 PM   #14
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I was trapped in my trunk for 2 days because I couldn't use a search on taptalk. Luckily some thieves saw my keys on the ground and intuitively opened the trunk using the hidden keyhole near the rear plates.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
trunk
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 04:27 PM
Open ECU? jedibow Software Tuning 302 10-09-2013 08:24 PM
Dealer that still open for a new order carlo1912 BRZ First-Gen (2012+) — General Topics 22 08-23-2012 07:11 PM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 11:20 AM
Open Air FR-S Concept Rampant FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 02-02-2012 12:01 AM
