Old 09-09-2012, 10:13 PM   #1
KamalT
Drives: Pearl 86 GT
ECUTek Support
Thought I would start a thread on ECUtek where we can all pool our experience to make the best of the product.
If there are trolling comments or negative comments, keep it to yourselves or start a new thread unless it is constructive.
I’ll start:
I had some issues installing and getting the flash done, no fault of John, different end of the world.
So here are the problem and solutions.
PROBLEM:
Installed software but the cable is not communicating.
Error: CANUSB drivers not found or CAN errors. Not communicating with car.
Solution: Go to http://www.ecutek.com/Downloads.aspx and select the Download Hardware Drivers and download the latest drivers.
PROBLEM:
Cannot flash car, error you do not have a license.
I’ll need more clarification on this one
Solution: Check to see id license is 1. I had two files sent to me. So do a license update with the first file and check license is 1. Once you run the flash, license should gets reset to 0. Update license file with new file and license will come as 1 again.
If you update license with the new license before flash. License = 0
PROBLEM:
When doing the ECUtek update. File cannot update.
Solution: Check your internet connection
If I am incorrect can someone please advise.
I also was have a look at the other application and it gets a lot of info. It would be good if they do something like the DEFI and the HKS OBD-II Apple and Android app and also maybe setup a live graph while you drive.
KamalT is offline   Reply With Quote
Old 09-10-2012, 12:31 AM   #2
Visconti
Drives: 05 STi
Hey - Great thread / post.
That information is going to be very useful.
I'll add it my Flash Info thread as well.
Thanks!
Visconti is offline   Reply With Quote
Old 09-10-2012, 01:04 PM   #3
Opposed
Drives: 2013 Asphalt FR-S
Not a problem, but after the flash is complete and you restart the car, remember to let it idle for a few minutes on its own. Do NOT apply any throttle during this part.
Opposed is offline   Reply With Quote
Old 10-22-2013, 03:25 PM   #4
kuhlka
Drives: 2013 BRZ Limited AT
I got my kit today, got all of the software installed, but when I try the 'Apply Feature Update' no file is in the folder to apply the license. Any ideas? I need to figure out how to get the Remote Update File (.upd file type).
kuhlka is offline   Reply With Quote
Old 10-22-2013, 03:26 PM   #5
FR-S Matt
Work with your tuner. There's normally a form you fill out where they validate your dongle ID, license, etc. They'll send you back the license to apply and a base tune file to begin your logging.
Old 10-22-2013, 03:42 PM   #6
kuhlka
Ah, got it. I shot an email off to Avo with my fob and reg info and got the file. Just waiting for a ROM back from them now that I know my ECU details.
Old 10-22-2013, 04:23 PM   #7
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
@Guff can you move this to the proper section please. Thanks.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-22-2013, 05:03 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
Mentions are hit or miss sometimes. If that doesn't work just hit the report button.
Old 08-23-2015, 12:28 PM   #9
scoobynewbie
Drives: 13 GBS BRZ, 05 BRP RS
So kind of an old post but I have checked the interwebs and can't find an answer...
I have ECUTek and a standard license but every time I try to flash a modified ROM I get the error:
This ECU Type can only be programmed with a standard ROM or a ROM that has had Racerom features installed. Select another ROM or apply RaceROM features from the ROM Editor
The changes I made were to delete the rear O2 sensor and based on ECUTek page, the standard license can do that and I don't need RaceROM....
Thoughts?
scoobynewbie is offline   Reply With Quote
Old 08-23-2015, 06:55 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thoughts?
What ROM are you trying to flash? I'd guess an OFT one?
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-10-2015, 02:21 AM   #11
Nbarnett5
Drives: Toyota gt86
I purchased my gt86 from Japan. Unfortunately it's restricted to 110mph. Does any one
I’ll start:
PROBLEM:
PROBLEM:
PROBLEM:
I purchased my gt86 from Japan. Unfortunately it's restricted to 110mph. Does any one have a fix for removing the restrictions?
Nbarnett5 is offline   Reply With Quote
Old 09-10-2015, 05:56 AM   #12
steve99
i dont know what the tables are called in ecutek but will be something like a speed limit fuel cut table. @Kodename47 will know
Old 11-02-2015, 01:22 PM   #13
scoobynewbie
I got it figured out. Hadn't checked on here in a while. I didn't realize you needed to activate the Racerom portion even if you didn't have Racerom features.
Mobile support (iPhone/iPad/Android) now available through tapatalk FT-MH Site Announcements / Questions / Issues 21 10-06-2016 06:35 PM
Your BRZ's first boo boo support thread Norcalmav23 BRZ First-Gen (2012+) — General Topics 131 10-24-2012 10:40 PM
Aftermarket Support Suggestions? HATED1 Scion FR-S / Toyota 86 GT86 General Forum 2 08-06-2012 03:23 PM
OptionJDM wants your support guys! OptionJDM Announcements, Contests, Giveaways 16 05-30-2012 04:33 PM
Difference in aftermarket support for FRS and the BRZ. Eureka Scion FR-S / Toyota 86 GT86 General Forum 39 04-16-2012 12:06 PM
