Old 09-11-2012, 11:43 AM   #1
jellygorilla
Drives: Whiteout FRS
Question Wheel Size vs. Balance
Hey guys.
I'm thinking about getting five axis R5 19 inch wheels for my FR-S. What are the down sides of having such big wheels? Will it throw the car off balance majorly from the already balanced stock setup? Also do I need to lower the car if i do install the wheels?
jellygorilla is offline   Reply With Quote
Old 09-11-2012, 11:46 AM   #2
chutrain
chutrain's Avatar
Drives: WRB BRZ
Yes, bigger wheels will most definitely throw off the dynamics of the vehicle. You will have additional unsprung weight, an inaccurate speedo, different gearing, and may not be as sharp handling wise. 19s are only good for appearance. Otherwise stick with a 17 wheel for performance.
chutrain is offline   Reply With Quote
Old 09-11-2012, 11:53 AM   #3
jellygorilla
Alright thanks, I guess my max size would be 18's then.
What if I get the tein springs that the dealership offers? It's suppose to drop it by 1 inch on my 17's. Is that even worth it? or should I just wait it out and buy some better stuff later?
Old 09-11-2012, 11:59 AM   #4
gmookher
what are your goals with the car?
gmookher is offline   Reply With Quote
Old 09-11-2012, 01:52 PM   #5
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Wow, I just started a thread on this same topic.
The only thing I want to add to what the OP posted is that I am going turbo next year.
Appearance of the tire is not important to me. I want something no heavier than the stock wheels (preferably lighter). I am looking at the JDM STI wheels for the BRZ which are 17x7.5j and also 18x7.5j.
I would prefer the 17's due to less weight.
I just want to know if the size and tire width with these wheels is able to handle an approx 275-300whp considering I go with the best tires.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-11-2012, 02:06 PM   #6
RavSpec
Drives: Rx7
for 275~300 WHP, u will need more tire width for better grip. Or better tires will also help as well.
For the mid level price range, u can check out the Yokohama S. Drive, Hankook K110 or the Falken FK452.
For higher end stuff, check out the Dunlop Direzza Z1 Star Spec, Michelin Pilot Sport, Yokohama Advan AD08, Hankook RS3.
I'll stay at 17" and 18" for cheaper tires and more tire choices.
Wheel weight does make a difference during auto cross and track, but for street, a few lbs differences will not effect too much.
RavSpec is offline   Reply With Quote
Old 09-11-2012, 02:23 PM   #7
ngabdala
Ok. Well I definitely want to go with the STI 5x100, 17x7.5j +48mm for wheels so I will buy the best tires I can. I must have those STI wheels.
What FT-86 wheel size do you want to see on production version? MR2fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 121 08-15-2012 01:57 AM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 01:01 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 01:34 PM
Stock Wheel Size Confirmed..? CoryUyede Scion FR-S / Toyota 86 GT86 General Forum 4 12-22-2011 01:26 AM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 04:06 PM
