Boostin'
Drives: FRS-T
I am wondering if you guys running turbo set ups are running a non return valve or check valve between the intake manifold and the brake booster. Also on which hose did you hook up the bov? I can only see one hose that could be used for that purpose. Lastly, the second hose on top of the intake manifold going down on the back of the block on the passenger side, should this get a check valve as well?
Drives: Black 2013 FRS
Most brake boosters have check valves built in so that you don't lose braking force if the engine should shut off.
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 01:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 09:06 PM |
| Best Booster Seat for FRS/BRZ | Kimsey47 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-07-2012 12:51 PM |
| Big Brake? | Ladnerd | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 32 | 04-30-2012 08:32 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
