Old 09-30-2012, 02:48 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Does one change the oil in an oil cooler?
I would like people's opinion on changing the oil when an oil cooler is fitted. I have done a little bit of Googling but I haven't read anything that is definitive. I agree with a couple of contrary opinions.
I have read that
1/ The hose couplings on a cooler are not designed for many cycles of remove/replace. (That makes sense)
2/ If one does drain the oil from the cooler it means the engine will start with out oil as the air in the cooler is replaced by oil unless one fills the oil cooler first. (This makes sense too)
3/ If one does not drain the oil from the cooler then when an oil change is carried out the new oil is immediately contaminated by the remaining old oil in the cooler.( Yep, that rings true).
4/ That the amount of dirty oil is negligible compared to the total volume of new oil. ( I would prefer 100% fresh oil, not 90% new oil).
People's thoughts on the matter would be appreciated.
Old 09-30-2012, 02:51 AM   #2
Josh B
Buzz Killington
Drives: A slow truck
You can never get all of the old oil out of an engine anyway, so IMO, the contamination bit wouldn't apply. Depending on how much the cooler adds in capacity, my guess would be 1/4 of a quart or so, I wouldn't worry about it. I have had a car with an external oil cooler and I never drained that when doing an oil change.
Sent from my PC36100 using Tapatalk 2
Josh B is offline   Reply With Quote
Old 09-30-2012, 02:55 AM   #3
s2kdrew
Drives: 2013 hot lava FRS
Same as all turbo car, kept a lot of oil at turbo. The oil turns all dark as soon as you start up the engine.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 09-30-2012, 02:59 AM   #4
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Its negligible. No worries.
Coheed is offline   Reply With Quote
Old 09-30-2012, 03:07 AM   #5
arghx7
Drives: car
Only if you've pulled the engine out of the car. Otherwise, drain and refill oil as normal.
arghx7 is offline   Reply With Quote
Old 09-30-2012, 03:08 AM   #6
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
^ This.
Evo's and more we change oil as normal. No issues and standard procedure.
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-30-2012, 03:11 AM   #7
gmookher
x2
gmookher is offline   Reply With Quote
Old 09-30-2012, 09:20 AM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Also, #2 isn't an issue since, when the oil is cold like at start up, the oil isn't being diverted to the cooler. The oil will follow the stock pathway.
Old 09-30-2012, 09:40 AM   #9
Shiny
Drives: 05 Ford F150 Scrow
As stated above. The quantity is small so no meager issue here to oil quality.
Unless the oil in your engine is contaminated (Oil Water mix …) then a flush before the oil change is required.
Or you have a huge heat exchanger (unlikely on road cars) J .
Don’t worry about it.
Smart phones, smart cars, smart television….. When are they going to make smart people?
Shiny is offline   Reply With Quote
Old 08-26-2015, 08:37 PM   #10
empower-auto
Kouki-Monster
empower-auto's Avatar
My HKS cooler adds like 1qt or more. That's a fair amount. I just stick to a low change interval.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-26-2015, 09:05 PM   #11
stugray
Drives: 2013 GBS BRZ Limited
My rules:
NEVER reuse an oil cooler from an engine that detonated.
They are relatively cheap, just replace it.
For oil changes, I built a tool that allows you to flush an oil cooler with new oil before hooking it back up.
My racecar external cooler(s) hold over 3 quarts.....
Old 08-27-2015, 07:36 PM   #12
Shady195
Drives: '13 10 Series FRS #1203
My rules:
The NSA is gonna love that picture.
Shady195 is offline   Reply With Quote
Old 05-08-2016, 03:39 PM   #13
Tor
Tor's Avatar
Drives: Toyota GT86
Cool tool! How does it work?
Tor is offline   Reply With Quote
Old 05-08-2016, 04:31 PM   #14
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
You fill the "pressure vessel" (c o o ker) with new oil and hook it to the cooler line.
Then pressurize with air to about 20 PSI & open the ball valve.
It will push new oil into the cooler and push the old out.
It is a little more important for my racecar because I have >20 feet of 12 AN hose and two coolers on a mid engine for about 3-4 extra quarts on a 5 quart engine.
justatroll is offline   Reply With Quote
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 09:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 05:30 PM
Greddy oil cooler coming soon DIG1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 08-20-2012 01:02 AM
Greddy Oil and Diff Cooler pdreams Engine, Exhaust, Transmission 3 06-13-2012 09:41 PM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 01:55 AM
