Old 10-04-2012, 12:55 PM   #1
SkullWorks
Drives: SSM LT MT BRZ
SMOG Issues
I'm a Cali resident, and having bought my car out of state, it is mandated that i have to pass a smog check before the registration can take effect on my vehicle. (yes even though it is on a MSO and is shown on the title as a California Emissions equipped vehicle)
So i take it to my friend 2 doors down that smogs all my personal and work vehicles, and go about my day.....several hours later he calls me to come get my car and says it barely passed, and man he wasn't kidding.
both the NOx readings and the HC's were within several points of failing, and I guess they had to run it several times to get it to pass...
Vehicle has the sound diverter removed as well as the resonator that hangs below the intake elbow, this shouldn't affect the metered airflow, but may have affected the direction the air follows as it passes the MAF sampling tube...having the MAF in a section so close to a bend is problematic in that way, if it were in a longer straight section of tubing it wouldn't be as sensitive to turbulence,
Anyone else had issues with a Cali Smog test?
Any other ideas?
SkullWorks is offline   Reply With Quote
Old 10-04-2012, 01:20 PM   #2
jeebus
Drives: 2015 Mustang GT (on order)
I had to smog mine too since I bought from out of state. It passed with flying colors. The NOx and HC were well within normal.
I'd say put your intake back to stock and see if your buddy can do a test run. If you are running that dirty right now, your car is bound to be running poorer than it should be, and will certainly have emissions issues down the road.
jeebus is offline   Reply With Quote
Old 10-04-2012, 01:25 PM   #3
SkullWorks
Yeah...turns out that's not gonna happen,
I just fitted R35 GTR injectors (570cc) and we are tuning it on E-85 tonight...
Next week the turbo goes on and the front cat comes out anyway...
Old 10-04-2012, 01:31 PM   #4
jeebus
LOL
Old 10-04-2012, 01:36 PM   #5
domsawww
Drives: 240sx
There are a couple threads about removing the "snorkel" on the stock setup and the adverse affects it has on the power. This could also be why you are getting high NOX readings and what not.
domsawww is offline   Reply With Quote
Old 10-04-2012, 01:46 PM   #6
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
There is only 1 thread citing a loss of power from removal of the snorkel, the others just quote the primary dyno for it. Here's the kicker... it was a loss of 1 peak HP, and that's perfectly normal for variance. I've had fluctuations of 2-3 hp on various dyno runs without making any changes to the vehicle.
Please stop the loss of power on snorkel removal myth.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 10-04-2012, 01:50 PM   #7
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I'd like to see more data on that as well. From what the guys at Airaid posted, with dyno charts, the removal of that front snorkel (inside the front bumper) acutally made additional power. Albeit it wasn't by very much.
If you have evidence otherwise I'd like to see it myself. Not because I own an Airaid intake, but simply out of curiosity. As if this is true, I may be inclined to put that snorkel back on.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 10-04-2012, 01:55 PM   #8
domsawww
Drives: 240sx
As i dont know first hand about it i only know what i read. But it is doing something to the motor when it is removed. All i was saying is that it might be the reason he is getting a weak smog test. AKA no snorkel (could) give MAF a wierd reading wich in turn (could) be causing his smog issue. Thats all
Old 10-04-2012, 02:23 PM   #9
SkullWorks
I moonlight at a Dyno, had the BRZ on there before and after snorkel removal, no change in HP outside of normal variance, no noticable change in logged A/F ratio either,
HOWEVER...full throttle Dyno Runs (usually closed loop) and open loop emissions testing have very little to do with each other....
Canadians with CEL and SL Issues KingRohan CANADA 93 03-28-2015 03:07 AM
Speaker issues. Hotlava86 Issues | Warranty | Recalls / TSB 19 10-18-2012 04:06 PM
Subaru looking into issues with the Nav TSY Issues | Warranty | Recalls / TSB 44 10-04-2012 12:43 PM
Question about smog checks/emissions showbe Scion FR-S / Toyota 86 GT86 General Forum 3 09-28-2012 01:03 AM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 04:41 PM
